It is currently Sun Oct 26, 2025 4:11 am
Post new topic  Reply to topic  [ 92 posts ]  Go to page Previous 13 4 5 6 7 Next
PostPosted: Mon Apr 23, 2012 12:24 pm
This is the current state of the swap. There is still a bunch to do. I had planned on working on it this weekend but my dad had a heart attack so that never happened.
I still have the passenger side brackets to remove that held the rear beam in place and the gas tank mounts for the front of the tank.
Last edited by 91talonharv420 on Wed May 16, 2012 12:18 pm, edited 1 time in total.
PostPosted: Mon Apr 23, 2012 1:14 pm
No point in drilling the spot welds.. I spend a solid hour doing that. JUST to cut that entire area out. because my lower control arms hit :oops:
PostPosted: Mon Apr 23, 2012 3:05 pm
Did you set your rear end height so that you needed to modify the tunnel for the carrier bearing? I am going to see how far away from the frame the rear end needs to be to not have to modify the tunnel. I know LILEVO did this.
PostPosted: Mon Apr 23, 2012 3:47 pm
He is right, you will have to clearance those spots. With the rear end sitting in the correct spot, it will still hit there.
PostPosted: Tue Apr 24, 2012 5:04 am
Based on every picture I have looked at of other swaps I figured I would have to do something there. I hope to get more done on it this weekend but I may have to work.
PostPosted: Wed May 16, 2012 12:15 pm
Been super busy at work and on weekends so the AWD progress hasn't really been going anywhere. I have ordered some parts and had some stuff powder coated.
Afco upper control arms
2000 degree ceramic coating on FP manifold
Wrinkle black powder coating
PostPosted: Thu May 17, 2012 12:28 am
That looks awesome!! :supz:
PostPosted: Sat May 26, 2012 3:23 pm
Looks awesome man :supz:
PostPosted: Sat May 26, 2012 7:28 pm
Thanks guys. I spent all day working on the rear sub frame. I had to cut off the stock upper control arms because the eccentric bolt was seized to the sleeve. I then had to press out the stock body mount bushings so I could weld solid ones in. I have a little grinding to do tomorrow before I get it powder coated. I also pressed out the mustache bar bushings and welded solid bushings in. I will take pictures tomorrow and post them up. I spent $20 on some steel that was waterjetted to create these solid bushings. I didn't feel like spending the money on boostx bushings.
PostPosted: Tue Jul 17, 2012 9:39 am
Finally updating with some more powdercoating pictures:
PostPosted: Sat Oct 20, 2012 7:30 am
This looks nice.
It's like looking at my build page.
Go have a look and tell me what you think. I've been building my car just week to week every nice job.
http://www.gsrcyborgclub.com/viewtopic. ... 952#p33952
Let me know what you think.
IRS awd evo3 rear floor colt check my build and tell me what you think
PostPosted: Sun Oct 21, 2012 5:19 pm
I have seen your build and I like it. Mine is gonna be simple but hopefully awesome. I am definitely taking my time. I needed to get tooled up for the project and feel I am now. Now I need motivation to finish the rear install.
PostPosted: Sun Oct 21, 2012 7:49 pm
It's looking good man. Have you made up the mounts for the rear end. I want to get my rear end pondered coated.
PostPosted: Mon Oct 22, 2012 3:06 pm
I havent yet. I am waiting on the hardware to put the rear end back together right now. Once I have it all I will be able to put it in place and get the mounts figured out. I did make brackets for the mustache bar to bolt to. Hopefully the rear end will be welded in by Christmas.
PostPosted: Mon Oct 22, 2012 4:32 pm
Cool man. You will get there.
You should of just changed the floor like me lol
Never agen haha.
