It is currently Sun Nov 02, 2025 8:14 am
PostPosted: Sat Mar 10, 2012 10:39 pm
i just converted to automatic so i am selling all of my manual parts. this will be great for the guys who want to swap from the 1.5l tranny, just need another tranny or from a km210.
tranny is from a 92 eclipse gst. synchros(single not double synchros) are replaced with new oem one 200 miles ago so the tranny shifts great under 7000rpm for 2nd gear(can use a double synchros upgrade) and will go into every other gears above 7000rpm with not issue. gears, hubs, synchros and sliders are deburred so you can shift with your pinky finger. input shaft bearing is a little noisy at idle because i shim it a little loose(did not want to wait for another shim from the dealer) but it does not make any noise during drive at all. i have the correct shifter levers from a km210 on it along with the correct bracket to mount the shifter cable. if you don't have the correct shifter levers and cable bracket, it will not select 2nd, 4th, and reverse correctly. tranny also has the 89 tranny mount so it will bolt right up to the factor body mount. i replaced the seals so it does not leak. the shift forks inside the tranny are replaced 200 miles ago so all gears will engage correctly. i like to get 450obo plus shipping for the tranny.
gst act street lite flywheel. i just go it resurfaced. 200 obo plus shipping.
exedy 2600lb pressure plate/exedy 6 pucks. only 3 passes on it. plenty of live on it. 250obo plus shipping
almost brand new clutch master cylinder (100 miles or less). got it from napa. 50 bux plus shipping
clutch slave cylinder (2000 miles). got it from napa. 30 plus shipping.
clutch pedal and brake pedal assembly from 89 mirage turbo. 100 shipping
stainless/factor steel clutch line. 30 plus shipping
fwd gst starter plate. 25 plus shipping.
correct length and good condition shifter cables. 100obo plus shipping
correct shifter and shifter base with good bushing. standard length and cut down/rewelded shifter included. 100obo plus shipping
if you want everything, i sell the complete swap for 650 plus shipping.
text me at 6788609924 for pics.
615hp and 475tq at 23psi and 75shots
http://gadsm.org/showthread.php?t=37685
PostPosted: Mon Mar 12, 2012 9:47 pm
still for sale.
PostPosted: Sun Mar 18, 2012 10:43 pm
taking offer. i might have to try craigslist now.
