It is currently Wed Jun 05, 2024 7:20 am
Post new topic  Reply to topic  [ 167 posts ]  Go to page Previous 18 9 10 11 12 Next
PostPosted: Sun Dec 04, 2011 5:31 am
I have seen this noted on here before but in NAPAs system they do not have the correct driver side axle listed under 89', it is listed as 88'.
Sorry, was to lazy to get part numbers :P but NAPA is 88' for our original turbo cars.
Same with carquest. The '89 turbo models were all made in '88 and then shipped over.
PostPosted: Sat Jan 21, 2012 4:02 pm
Changed my mind about the napa axles and went ahead and ordered a drivers axle from carquest. Figures it came in the wrong part but with the right p/n. It seems that they can get the empi drivers axle so I went and ordered it. works out better for me, I didn't want the thinner remans anyhow. Let it be known that they cannot get the pass side empi though. I am goin through fishers auto for the pass side.
PostPosted: Sat Jan 21, 2012 7:25 pm
Owner/Admin
I can get any axels you need, even the 89 mirage turbo axels.
PostPosted: Fri May 11, 2012 12:41 am
ok question guys..
89 colt gt. auto swapped to f4a33
awd talon intermediate shaft and halfshaft. (axel bottoms out ) and is extremely cambered to where i cant get a bolt in.
what do i need to make the intermediate shaft work?
PostPosted: Fri May 11, 2012 6:13 am
Original gt axles
PostPosted: Fri May 11, 2012 4:12 pm
so the gts came with an intermediate shaft on the drivers side? i would really like to get this 5 lug to work
PostPosted: Sat May 12, 2012 12:38 am
I believe all 4g61 powered csm's came with an intermediate shaft but don't quote me on that. There were GT models that were powered by the 4g15 so don't expect to find one on one of those.
PostPosted: Sat May 12, 2012 12:52 am
I think he's talking about the gts 2nd gen turbos, and from the info on here they are believed to be the same axle and intermediate shaft on the drivers side.
PostPosted: Mon May 14, 2012 12:58 am
from what i have seen the 2g g32b turbo colts use the same axles as the 3g 4g61t colts. I have been running a set in mine now for 2 years that i robbed from the local pick a part 2 years ago... no issues at all!
-1989 Colt GT (stock for now)
-1993 Dodge colt 4g63 swap
PostPosted: Tue Oct 13, 2015 1:36 pm
I have an 89 turbo gt and recently swapped a F5m33 91+ 1g dsm transmission.. The car is running GVR4 front brakes and spindles.. I believe I am also running the turbo GT Intermediate shaft.. I'm not sure what axles are on the car, although they work, I may need to replace or repair the CV joint or the whole assembly.. What axle should I use?
PostPosted: Tue Oct 13, 2015 1:59 pm
mirage turbo axle.
PostPosted: Wed Oct 14, 2015 6:42 am
Carquest is not showing anything for the car 88 or 89. Anyone have any recent leads on where to buy a set where you actually recieve the correct axle? Rockauto ect?
PostPosted: Wed Oct 14, 2015 11:24 am
I recently got both sides from Carquest, they have been working great. Drivers is MI-8133 13239 Surtrack, NCV37015 on the box. Passenger has HY-8085 on the box.
PostPosted: Wed Oct 14, 2015 11:45 pm
Are you looking it up as a '88 Mitsu Mirage turbo?
PostPosted: Wed Oct 28, 2015 10:12 am
Thanks. Shows up on rockauto with same PN for about 45 each.. I will give them a try..
