It is currently Mon Apr 29, 2024 11:04 am
Post new topic  Reply to topic  [ 144 posts ]  Go to page Previous 14 5 6 7 810 Next
PostPosted: Thu Dec 15, 2011 11:22 am
Micah was nice enough to let me take the car to work today. It runs amazing well for 10psi and 3-minute butt tune. Still have clutch issues and probably trans (grinds sometimes). Once that is figured out we'll up the boost and go tune it at RRE.
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Thu Dec 15, 2011 11:50 am
dan was nice enough to help me w/ the build and tune. anxious to hear what the coworkers think. i can only imagine...
PostPosted: Thu Dec 15, 2011 2:47 pm
You guys did an auto-manual swap correct? What trans is in the car now?
stock final/rear end ratio same as DSM?
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Thu Dec 15, 2011 2:53 pm
Complete 1G AWD 5spd drive train. It was an auto car previously.
'18 X5
'19 M5 Comp
'17 Fiesta ST
PostPosted: Thu Dec 15, 2011 4:13 pm
I am so close to doing this to my van. If I have to drop that heavy ass AWD automatic again it will probably not be going back in.
PostPosted: Thu Dec 15, 2011 6:07 pm
Do you know what the stock 5 speed front diff final and rear end ratios are?
Current
08 535ix 420awhp
PostPosted: Thu Dec 15, 2011 6:14 pm
Engrish!
PostPosted: Fri Dec 16, 2011 9:48 am
Fixed lol
Current
08 535ix 420awhp
PostPosted: Fri Dec 16, 2011 11:00 am
For the van or for the 1g stuff?
PostPosted: Fri Dec 16, 2011 4:05 pm
Stock 5 speed Van ratios....
Current
08 535ix 420awhp
PostPosted: Sat Dec 17, 2011 12:08 am
1993 5 speed awd vans are identical trans as 2g awd dsm, aside from the vc unit and housing to support it. (easily swapped out to make full dsm trans) t case is same as 92-on and rear diff ratio is the same. All you need with an awd van is a dsm engine and 1 motor mount. Its a super easy swap. But if you do what micah did then not so much. This swap was a hell of a lot more work than mine.
I dont know but i would bet the auto awd trans is borrowed from dsm too? and rear diff would also be sameratio as auto dsm? I just wish they would have used a dsm rear diff so a guy could swap in an lsd unit easily.
PostPosted: Sat Dec 17, 2011 1:47 pm
Great info-
As far as the diff, as long as the width is about the same, I bet the outer splines would be as well!
Current
08 535ix 420awhp
PostPosted: Sun Dec 18, 2011 4:09 pm
i just started on my mitsubishi expo 7 passenger van, pulled the motor, I'm waiting on a couple gaskets and i still need to tap my intake manifold for my map sensor(running sd) then ill be dropping in a fresh fully built motor. awesome work though any updates?
PostPosted: Sun Jan 15, 2012 12:39 pm
Sorry if I missed it but what did you guys use for the trans mount on the frame rail?
PostPosted: Sun Jan 15, 2012 1:37 pm
i swapped the mounts from the summit to the 2.0 it all bolted up, mine was originally manual and awd.
