It is currently Tue Oct 21, 2025 1:55 pm
PostPosted: Wed Nov 23, 2011 10:47 pm
My relocate had the terminal so high that it touched the roof of the box I had it installed into. Needless to say, the box was grounded thought the threaded rods down though the 1" square tubing and into the frame. Learned my lesson, but a kill switch = GOLD.
PostPosted: Thu Nov 24, 2011 1:24 am
so you swapped this from a auto to a 5 speed? did you remove the dash and take the brake peddle off that way?..also do u still have the auto peddle assy? I might be interested in it if price is right.
PostPosted: Thu Nov 24, 2011 3:49 am
Yea the battery is one of those things i have to finish up, I just thru the bungee on there so i could test drive it. Once i work on making the exhaust and pull the stock muffler off the back and that heat shield above it i will be able to put it in a box and tighten down the studs to hold the box to the metal.
slowdsm:
yea i pulled the dash to switch the pedal assemply out, at first i tried to do it using the stock auto brake pedal but its literally too big and is too close to the clutch pedal also the brake light switch is in a different spot, so the manual pedal is a must.
Yea i still have the pedal/cross bar, send me a your zip code and i'll try to find out shipping for it as its pretty long and im not sure how much it will cost to get it shipped.
Who do you think you are? I AM.
92 colt 4g63t
91 talon tsi 'neverending project'
91 NISSAN 240 SUPRA TT CANDIDATE in the making
I LOVE THE 90s
PostPosted: Thu Nov 24, 2011 5:21 am
Plastic battery boxes can be bought at Walmart for $9. Different sizes and they come in black or red.
PostPosted: Thu Nov 24, 2011 11:55 am
yeah its long and bulky.. I did the same swap in my car 3 years ago when I got it.. now im going back to auto soon.
zip is 85712 thanks
