It is currently Mon May 06, 2024 1:00 am
Post new topic  Reply to topic  [ 268 posts ]  Go to page Previous 1 2 3 4 518 Next
 Post subject: Re: 91 Eagle Summit AWD
PostPosted: Wed Nov 09, 2011 4:07 pm
I miss spoke, it is a TDO5H 18G with a tdo6 cover. .. Yes very much like the greddy 18gs of years younder. Should serve this tin can quite well.
Warren
PostPosted: Mon Nov 14, 2011 2:48 pm
Had a little bit of time last week, to install the front mount, this is a 10.5 inch race FMIC from ets ( used to be on jeremys car) .
Some shots of the initial mark up
Next up was the intake manifold with some of the trimmings on it, i.e rail, coil pack and the additional vacuum points that were tapped into it. Nothing fancy here, just a 199x intake manifold with turbo TB and ets short route piping.
and an engine shot
Image.
I have already finished the upper IC pipe to attach to the intercooler. I however have to come up with a creative solution for the lower .
More to come as always.
Warren
PostPosted: Wed Nov 16, 2011 7:30 am
Pictures of the FMIC Bolted on . There was significant trimming, to get the intercooler to sit pretty close to the radiator core support. I ended up using some pretty thick aluminum to bolt everything up
in the picture below , you can see the amount of metal trimming that had to take place
Image. Significant sheetmetal had to be removed directly behind the headlamp assembly.
I also folded the pinch weld on the radiator core support, so that the scirroco radiator could fit appropriately. You can see that in the bottom of the picture below
here is a shot of the upper IC pipe attached the FMIC. I really liked the way it came out
and last but not least a shot of it nice and tucked and undercover ;)
more to come as always
Warren
PostPosted: Wed Nov 16, 2011 8:29 am
That is a nice looking IC setup. You gonna leave it black?
PostPosted: Wed Nov 16, 2011 8:41 am
It is not paint, the FMIC is annodized black. I am leaving it like that.
Warren
PostPosted: Wed Nov 16, 2011 8:53 am
Agreed in that case. You would ruin it trying to get anodizzing off it...
PostPosted: Tue Nov 22, 2011 7:43 am
Clutch is in,
basically , act pro lite flywheel
2600 Pressure plate
street sprung hub disc
Transmission is on the car now and progressing forward with old girl
Warren
PostPosted: Tue Nov 22, 2011 1:47 pm
Very nice progress and build, will be keeping an eye on this one 8)
PostPosted: Tue Nov 22, 2011 9:09 pm
more progress
pictures of the transmission in
this thing is starting to look like an engine bay again
SANTA 6bolt2g came by early this year with 72# injectors, a tial wastegate and a greddy blow off valve, fuel rail fittings and line
Also received the last coupler in the puzzle for the lower ic pipe
I think it turned out sweet
next was mocking up the radiator location
an finally this pig has some interior parts
Warren
PostPosted: Tue Nov 22, 2011 11:57 pm
It's starting to get there! Keep up the good work, the bay is looking good.
PostPosted: Wed Nov 23, 2011 12:01 am
Scirocco radiator right? Trans looks real clean!
PostPosted: Wed Nov 23, 2011 7:59 am
thanks aaron, I appreciate it.
shaun, yes that is a scirrocco radiator. tonight I will bolt up the wastegate and all the couplers to the IC
as well as the Transfer case. The car should be on the floor tonight, so It can be rolled into the other garage for some welding ;)
stay tuned
Warren
PostPosted: Wed Nov 23, 2011 1:10 pm
that radiator is so lovely.. fits right in there
i found mine on amazon for $37 brand new too 8)
1990 Colt AWD 8.8
PostPosted: Sun Nov 27, 2011 12:24 pm
happy thanks giving everyone,
I was able to do a little work on the car over the holidays, buttoned up some stuff in the front end, and after a long time, here is the car on the floor, with mostly everything done under the engine bay( mechanical wise).
a shot showing the fuel line out of the rear
and a shot of the rear of the car on the ground
Someone earlier asked about drupe distance, so here is a profile of the car , the front is lowered to the height that I want, however the rear will need to be redone
Basically I will need to cut the extension pieces so that the car can be level. In the picture above I can not lower the coil overs anymore than they are
with the front mount done
cameo shot with the other pile of junk ( if you look closely you will see the 3rd pile of crap also)
So I Began working on the tunnel and is basically welded completely in. Here are some poor pictures of it , it was a long day forming and welding this in
a shot of where the cell sits,
next up is some body seam sealer and paint.
Warren
PostPosted: Sun Nov 27, 2011 12:48 pm
I thought the rear would sit ALOT higher then youd want.. Idk why they welded that stuff on the rear hubs.. With lowering the shock towers, it should have been fine.
Looks good. making alot more progress then i am. :finga:
