It is currently Sun Apr 28, 2024 7:56 pm
Post new topic  Reply to topic  [ 268 posts ]  Go to page Previous 1 2 3 4 518 Next
PostPosted: Tue Jun 21, 2011 10:32 am
blind rivits work great like cherrymax can get at theyard.com or any other aviation supply company for cheap and they use a regular rivit puller
89 turbo chili
92 gvr4 96/1000- sold to mois used car lot
PostPosted: Tue Jun 21, 2011 11:49 am
this is what I have in my drag car
the one that I am building will look similiar to it
Warren
PostPosted: Tue Jun 28, 2011 6:30 am
Finished up the fuel cell enclosure,
Also both front knuckles have been pulled out, so that we can replace the front wheel bearings The next big fabrication thing that will be tackled, is the tunnel. I hope to work on that this weekend.
Warren
PostPosted: Thu Aug 04, 2011 6:38 am
More fuel work
here is a shot of the supply and return lines which I bent up in hard line, they are run along the frame rail
next the vent and return line, junction into bulkhead fittings and back again into the fuel cell. The fitting that goes into the fuel cell are a couple of tricky ones . They are -8 AN O-ring Boss fitting on one side, to a 90 degree -6 AN swivel male fitting ( what a mouthful )
Warren
PostPosted: Thu Aug 04, 2011 10:32 am
why did he make those strut extensions on the control arms for?
With my AWD, I just added 2'' to the bottom of the strut and it sat fine, with him lowering the strut towers, and raising that up, Id think it would be to much.. hows it sit with tires on it?
PostPosted: Thu Aug 04, 2011 1:49 pm
it sits pretty well, with the car in the air, there is massive amounts of travel (Drupe distance)
Warren
PostPosted: Thu Aug 04, 2011 2:38 pm
How much up travel does it leave? Just curious as I used to get 3ish inches of up travel on a 1.6 60' I was using GC coilovers
PostPosted: Fri Aug 05, 2011 11:34 am
I am not sure how much up travel it has, because the car has not been on the ground for a while. It is using dsm kybs and ground controls as well .
Warren
PostPosted: Sat Aug 06, 2011 3:59 am
The fuel cell enclosure looks good! I need to make one for my car. Where did you the the access door for it?
PostPosted: Sat Aug 06, 2011 4:54 am
Everything is looking good.. I was just curious about that..
Where did you get that alum line? how much was it?
PostPosted: Mon Oct 31, 2011 8:59 am
Engine specs are 2g pistons on 1g rods
light port work on the head, with crower springs and retainers.
the bare bay
I like this picture this is the turbo that is going on the car, td06 16g
done
more to come as always
Warren
PostPosted: Fri Nov 04, 2011 2:23 pm
I wish I could be making this kind of progress. Still need that front bumper/lip?
PostPosted: Mon Nov 07, 2011 8:12 am
Ben I still need that bumper and lip, we will plan to come and grab it one of these days.
Our weekends have been swapped with work, so that leaves me with very limited time to work on the colt. Non the less here is some progress.
I purchased a td05 rebuild kit and decided to rebuild the turbo that I was going to use. I am glad I did this, because there was sludge all over the cateridge and heat sheild.
I also had to drill out a broken stud in the turbine housing, which only took, oh maybe 5 hours :(
here is another shot
Image.
So to summarize the turbo set up. It is a tdo6 16g. The benefit of it is a compressor cover that allows me to downward face the Charge pipe. Which helps significantly in a space constrained colt engine bay/
I also installed a stock intake manifold that I had laying around. Next up will be mounting the ETS race front mount .
Warren
PostPosted: Wed Nov 09, 2011 7:52 am
This is so goood :) Awesome. Keep up the good work!!
PostPosted: Wed Nov 09, 2011 10:22 am
Turbo looks like a GReddy 18g without the GReddy badge to me.
Users browsing this forum: No registered users and 82 guests
