It is currently Sat Nov 01, 2025 4:01 am
PostPosted: Sat Oct 15, 2011 1:53 pm
okay. here's the deal.
I just stalled my FMIC.... Checked and re-checked all connections.... When the car hits 5000 rpm it sounds like the car is hitting the rev limiter. I checked my ECM link settings and the rev limiter isnt supposed to engage til 7000 rpm....
WTF.
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Sat Oct 15, 2011 2:38 pm
What is the 2step set at?
I had my 2step at 5500 with the AWD colt, I accidently kicked the clutch wire off to enguage the 2step, So it would only rev to that 5500, no higher.
PostPosted: Sat Oct 15, 2011 3:04 pm
Is it doing this even when sitting still? What MAF are you running?
PostPosted: Sat Oct 15, 2011 3:20 pm
Ditto on this. My clutch wire wasn't on and my 2 step became my new rev limit.
PostPosted: Sat Oct 15, 2011 4:48 pm
Or if your speedo cable breaks, you'll automatically be limited to your launch limit, cause it assumes your going 0 all the time.
PostPosted: Sun Oct 16, 2011 4:30 am
GM MAF....
Geoff
89 2.0 Turbo Colt
PostPosted: Sun Oct 16, 2011 4:31 am
I accidentally kicked the clutch wire off to engage the 2step, So it would only rev to that 5500, no higher.
I HAVE been under the car previously running some wiring so it's entirely possible that wire had come loose. I'll check that connection
Geoff
89 2.0 Turbo Colt
PostPosted: Sun Oct 16, 2011 6:02 am
I didn't install the "clutch" wire. Dunno if that means anything. :oops: I was able to rev to 7000 no issues.
4g61t.com
PostPosted: Sun Oct 16, 2011 6:05 am
No worries, I'll get under there and check it out!
Geoff
89 2.0 Turbo Colt
