It is currently Mon Jun 03, 2024 9:57 am
PostPosted: Fri Jun 27, 2003 5:00 pm
hey guys,
i'm really starting to have a problem with my 89 non turbo colt. it just began idling really rough and i havnt done much of anything to the car. the only thing that i have done is to take out the air silencer from the air intake. the car is idling so bad at times that it actually shuts off, but will start right up.....i gave it a tune up (plugs, wires, cap)....dunno what to do, any ideas
Stew
PostPosted: Fri Jun 27, 2003 10:11 pm
Nobody Important
air silencer? by that do you mean the honey-comb?
If so, thats not a good thing as the MAS needs it to get an accurate reading. (not 100% true, but we can clarify that later)
PostPosted: Fri Jun 27, 2003 10:23 pm
If you think the removal of that piece is causing the rough idle, put it back in and see if it goes away.
If it is indeed the honeycombs that you took out, then you REALLY need those put back in.
PostPosted: Sat Jun 28, 2003 7:42 am
hey guys,
There should not be any problems because of air silencer removal,
Otherwise it is not recommended to do any shit with the honeycomb.
It's rather serious..
PostPosted: Sat Jun 28, 2003 4:59 pm
the air silencer is not the honey comb....if you look on the opposite end, u'll see a white star shaped thing - that is the air silencer...shouldnt be any harm in taking it off i was just seeing if anyone knew of any harm being done because of it....thanx for the suggestions
Stew
PostPosted: Sat Jun 28, 2003 5:06 pm
actually when i took mine out it helped out my idle but yea if you think tha's the problem put it back and see it it fixes it
1983 Honda VF750F
1986 Chevrolet C-10 305
1990 Eagle Summit ES 4g63na 5spd
1990 Chevrolet Corvette L98
1996 GMC Suburban 454
1999 Volvo S70 AWD L.P.T
