It is currently Sun Apr 28, 2024 12:41 pm
 Post subject: hello guys
PostPosted: Sat Feb 12, 2011 11:28 pm
whassssss up
 Post subject: Re: hello guys
PostPosted: Sun Feb 13, 2011 11:12 pm
Just finished a compression test on my g32b, it was cold but I got 165-175. :supz:
Unfortunately, my IM to head gasket is leaking and causing a lean condition. But at least I can fix it, I was getting ready to scrap the car.
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Mon Feb 14, 2011 7:52 pm
scrap a mirage is a sin,,,,,,,,,, good luck with your project
PostPosted: Sat Mar 19, 2011 9:10 pm
scrapping a mirage is a sin. I will have a hard time letting go of mine too. Hence why it is still parked in the garage, since 2006. Waiting for the day I have time to do the 4g63 swap.
DRCOLT
1989 3g Colt GT turbo w/4g63t
PostPosted: Sat Mar 19, 2011 9:23 pm
I'll give it a good home if you're not going to use it.
PostPosted: Sat Mar 19, 2011 9:49 pm
OH, believe me, I want to use it, otherwise I wouldnt be holding onto it. Still starts every time I crank it, once every few months! I will take it around the block and pollute the air with burnt oil and front right side tire smoke! Actually took it out today to put a new garage door on. Man I miss driving that car. Thanks for the offer though.
DRCOLT
PostPosted: Sat Mar 19, 2011 10:25 pm
Negative Nancy
Man Im fukin bored!
PostPosted: Tue Mar 29, 2011 5:07 pm
unfortullay i traveling too much and have no time to work in the mirage , i already started to take all the interior out then i will move to the outside, doors, fenders, engi/tranny, bumbers, windows,,etc,etc,etc i will leave it on its own skeleton,, sand blast everything and from gold color is going to be WHITE, same bitch but with a different color,,, :supz:
it will take time but it will be done
PostPosted: Wed Mar 30, 2011 9:29 am
If your going through that extent for a color change go with something a bit more exotic.... Like a pearlescent white, or anything else. Thats alot of work for just white lol. Good luck, if you need anything answered about painting I can give addvice.
1994 Laser R/T 4G37 Turbo
1992 GTA Trans Am 5th Anniv.
1989 Silverado
1984 Maserati Biturbo 2.5TT
1980 Turbo Trans Am
1976 Trans Am 455
PostPosted: Wed Mar 30, 2011 10:27 am
Oscar
When you did your swap, did you keep the old g32b fusible links and not the fusible links on the 4g63 engine harness?
I'm using the swap wiring images you posted a while back to do my swap wiring and am pretty sure you used the old g32b stuff off the positive battery side.
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Sun Apr 10, 2011 10:19 am
jon i keep the fuse box from the mirage and discarted the one from the eclipse harness,,,, let me know if you need any help with the wiring,, so far mine havent cought in fire so i guess is good :o
PostPosted: Sun Apr 10, 2011 10:21 am
jonj cualquier cosa me envias un privado
PostPosted: Mon Apr 11, 2011 12:51 pm
Oscar,
Esta bien!!
I removed the DSM MPI plug and wiring and spliced the DSM engine harness into the c13a interior wiring and mpi relay. I have the g32b running now with MPI, using a 4g37 IM, 2L sohc optical distrutor for the CAS/TDC signal, DSM blue 450cc injectors, and custom e931 eprom running speed density! I'm finishing up the engine loom now. Hope to be driving if by the end of the week.
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
