It is currently Wed Oct 22, 2025 10:18 pm
 Post subject: Throttle cable question
PostPosted: Sat Jan 29, 2011 7:47 pm
I can't seem to get full throttle after the swap. It seems like the throttle cable is to long. Do I need to track down an 89 gt cable? Im using a 4g15 sedan cable. (car was auto if that matters.) im bolting the cable to a stock 4g63 intake manifold. I'm wondering if the gt cable will work better being that the 61 and 63 manifold are the same style.
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Sat Jan 29, 2011 9:33 pm
The throttle cable fitting that bolts to the intake manifold should be fairly slotted, about 1/2" of slot on each hole. This is what I used to adjust my cable tension. If it has these slots and you cant seem to get it adjusted properly I would run a 61 or 63 cable, although I'm sure a little fab work can make it happen with your current cable.
PostPosted: Sat Jan 29, 2011 10:03 pm
The factory 4g15 cable I am using is slotted and in it's tightest position im still only getting about 1/2-3/4 throttle.
2000 Lexus sc300
2016 ram 1500
PostPosted: Sun Jan 30, 2011 12:23 am
On my last swap I ended up not using either of the stock mounting points for the cable. Instead I used one that is a little further back and only used one bolt to hold it down. I think I remember someone posting a while back that they went to Autozone or Advance and purchased a 4G61 cable for a 89 turbo and got an actual Mitsu oem cable from them though so you may want to look into that too.
PostPosted: Sun Jan 30, 2011 8:35 am
http://www.4g61t.org/forum/viewtopic.ph ... le#p259785
Yea I saw this thread too. But I ran that part number, and I think it's for a Dsm. I would buy a gt cable if I could find that part number
2000 Lexus sc300
2016 ram 1500
PostPosted: Mon Jan 31, 2011 9:05 am
mirage 1.5 cables dont work on 4g63's you need a dsm cable.
PostPosted: Mon Jan 31, 2011 9:49 am
Will a Dsm cable mount to a CSM firewall?
2000 Lexus sc300
2016 ram 1500
PostPosted: Mon Jan 31, 2011 9:55 am
yes. my buddy tired a 1.5 cable in this dsm it bolted up, he ran in to the same issue you did
PostPosted: Tue Feb 01, 2011 9:36 am
A flat piece of metal and some self-tapping screws can fix the situation. I took the piece of metal that bolts to the IM and ran a couple screws through it into my fabbed metal plate. I then marked my fabbed plate where it should mount to the IM while keeping the throttle cable taught. Drill out holes where the marks are and bolt back to the IM. Here's a pic where you can kinda see what i did. Total time was about an hour.
PostPosted: Tue Feb 22, 2011 12:07 am
a 4G CSM cable will work... but you have to only use one bolt to hold it down and use the most drivers side hole.
-1989 Colt GT (stock for now)
-1993 Dodge colt 4g63 swap
PostPosted: Tue Feb 22, 2011 7:43 am
I made my 3G cable work
2000 Lexus sc300
2016 ram 1500
PostPosted: Tue Feb 22, 2011 9:14 pm
Why don't people just get the 4g61t cable from Mitsu or any other site that will list one? I have a 4g61t car and a 4g63t was installed, and it works properly with no issues or iffy fabbing.
PostPosted: Tue Feb 22, 2011 9:54 pm
I'll get one eventually
2000 Lexus sc300
2016 ram 1500
PostPosted: Thu Feb 24, 2011 10:01 pm
CSM Dik
DSM cable will work,but the hard metal housing must be bent through trial and error. Took me a few minutes but not a big problem.
Dale
PostPosted: Fri Feb 25, 2011 9:47 am
Why don't people just get the 4g61t cable from Mitsu or any other site that will list one? I have a 4g61t car and a 4g63t was installed, and it works properly with now issues or iffy fabbing.
Thanks for your confidence in my fabbing skills. :butthead: Most of us on this board try to spend the least amount of money while getting the most from our vehicles. That being said, why spend extra $ on a throttle cable when you can use what you have and spend nothing. Jerry-rigging is not in my vocabulary, and my 1.5L cable has worked for 6 years this way with perfect throttle response and no adjusting needed.
