It is currently Tue May 21, 2024 12:38 am
Post new topic  Reply to topic  [ 272 posts ]  Go to page Previous 13 4 5 6 719 Next
 Post subject: Re: whe3ls's hyundai
PostPosted: Thu Jan 13, 2011 11:10 pm
I always used high tack spray or Indian head is much better than RTV. Some times if you get RTV you might clog your coolant system, I've seen that happen before,lol.
PostPosted: Thu Jan 13, 2011 11:15 pm
That would take a lot of RTV to clog the coolant system LOL...
PostPosted: Thu Jan 13, 2011 11:32 pm
ok so should i use the gasket that came with the pump. and use a very small amount of rtv. usually i never use it
PostPosted: Fri Jan 14, 2011 4:37 am
Use both. Put a small layer of RTV on the gasket. It is not a good idea to attempt to bolt an aluminum water pump to a cast iron block without a paper gasket between the two.
PostPosted: Fri Jan 14, 2011 8:36 am
ok thanks
PostPosted: Sat Jan 15, 2011 10:14 pm
i put my timing bely back on. and as i hand crank the engine the belt is trying to work its self off the idlers and cam gears
PostPosted: Sun Jan 16, 2011 7:03 pm
it runs woot
PostPosted: Mon Jan 17, 2011 8:29 pm
i had it running now all it does is flood its self
i think i may have found a 93 auto tsi for a swap, its a complete running car, i hate to swap a 7bolt but its a auto so it shouldnt bad
PostPosted: Thu Jan 27, 2011 10:46 pm
so i doesnt want to start now... im saying f it this engine has had issues from day 1, i found a 4g64sohc that im swap my good dohc head on it and calling it good for now.
PostPosted: Fri Jan 28, 2011 11:21 pm
You might have a bad ECU problem because I have seen this before. If you can swap it out, that might be your issue because if you really think about it what will cause the injectors to stay open longer to flood it? ECU gives that sign when to fire by using CAS to know what cylinder it's at. In my opinion it would start there :wink:
At yeah if you get a 93 tsi the 1g 7 bolt blocks are not as bad as the 2gs, if your getting a good deal for the car I would say go for it, :yawinkle:
PostPosted: Sat Jan 29, 2011 4:12 am
the 93 had bad body damage, buying a 90-91 rst tomorrow
PostPosted: Mon Apr 11, 2011 9:05 pm
I found a expo in the local junk yard today. It still had the wheels on it so a picked those up. There 14 inch 5 spoke wheels.
PostPosted: Tue Apr 12, 2011 9:34 am
Nice reems! New rubber is a must.
PostPosted: Tue Apr 12, 2011 8:27 pm
ya i need to find what would be the best sized tire
PostPosted: Tue Apr 12, 2011 10:12 pm
Wow Ive never seen those wheels before, Nice Find! They look good! I love the bra too, I have to finish my Bra install!
92 Eclipse GSX (Dead)
89 Colt GT (AWD Swap) H1C
88 Cummins Suburban
69 Cutlass convertible
