It is currently Sun Jun 16, 2024 1:51 am
Post new topic  Reply to topic  [ 39 posts ]  Go to page Previous 1 2 3
PostPosted: Fri Dec 31, 2010 9:33 am
Finally finished the head. Got the GSC S3 Cams with GSC Beehive springs and retainers, fresh valves job with 1mm over size valves. I also got a Kiggley Flex plate and HLA Pressure Ragulator.
PostPosted: Sat Jan 01, 2011 10:40 pm
that looks sick
PostPosted: Tue Jan 04, 2011 6:52 pm
Did a little more work. Got the interior almost done and finished putting the head together.
PostPosted: Tue Jan 04, 2011 7:12 pm
Looks legit.
PostPosted: Tue Jan 04, 2011 10:14 pm
sick...
PostPosted: Thu Jan 06, 2011 9:04 am
I think the evo 1-3 rear subframe goes in pretty easy on the 4g cars from what I've read.
I couldnt tell what has been done besides cutting out the spare tire hump which I think was only done for the cell. Looks like they drilled a few holes and bolted it all in. They had a complete donor car when they did it. Almost all the parts from this car are from the RWD AMS EVO 1.
http://www.pixcl.com/summitgtx/lancerproject_1.htm
http://www.pixcl.com/summitgtx/lancerproject_2.htm
http://www.pixcl.com/summitgtx/lancerproject_3.htm
PostPosted: Thu Jan 06, 2011 11:29 am
That rear end assembly he built has to weigh a ton.
Im gonna remove the rear end on mine and I will take a bunch of pics of what was done. The drive shaft looks goofy, its all crooked down the middle of the car.
PostPosted: Thu Jan 06, 2011 1:11 pm
Trev man this thing is awesome. I don't know any other word to describe it. I've been watching this since you first posted it and I can't wait to see what this thing can do. Keep up the good work bro! I can't believe you have as much time as you do to work on your own cars after working on everyone else's at the shop all day. Now THAT'S dedication.
PostPosted: Thu Jan 06, 2011 10:46 pm
Helps when you hire monkeys to do all the hard work for you.
