It is currently Mon Apr 29, 2024 7:11 am
Post new topic  Reply to topic  [ 108 posts ]  Go to page Previous 14 5 6 7 8 Next
 Post subject: Re: Bolt up cross member
PostPosted: Tue Sep 28, 2010 6:08 pm
Not sure
PostPosted: Tue Sep 28, 2010 6:37 pm
hmmm quick question, would that bolt in to my elantra?
No, the elantra cross member is about 2" longer than the csm ones.
PostPosted: Fri Oct 01, 2010 10:34 pm
i see. :(
PostPosted: Thu Jan 27, 2011 12:23 am
Yea, I tried an elantra xmember for my fwd 4G63t swap and it was too long. I ended up using my stock one
92 Eclipse GSX (Dead)
89 Colt GT (AWD Swap) H1C
88 Cummins Suburban
69 Cutlass convertible
PostPosted: Fri Jan 28, 2011 11:27 pm
I used the elantra cross member and drilled 2 new holes :twisted:
PostPosted: Wed Feb 23, 2011 1:07 am
Damnit tom, You didnt state that on your Cardomain page! I saw you used one but didnt say you modified it! haha, No worries, My car is running fine.
88 Cummins Suburban
PostPosted: Wed Feb 23, 2011 1:35 am
Sorry buddy, didn't mean to screw you up like that,lol. :cry: But yeah you taught me something as well about the axle problem so we are even then :wink:
 Post subject: Re:
PostPosted: Thu Apr 14, 2011 1:28 pm
WAOOOO!!! Bolt up cross member....
I got one of this laying down in my garage with mounts. I bought it from NZ.
Paid bigggg! $$$ to get delivered to Connecticut.
When looking under the car if you look on the pass sideof the floor there are two bolt hole that have nothing in them.Looks like the same spacing as the bolt holes for the fwd cross member.This is where the back of the crossmember bolts up to.The front bolts up like stock
So, you have made a crossmember to substitute for this factory piece?
PostPosted: Fri Jun 03, 2011 9:45 am
Yeap bolt up. No complaints whatsoever.Tested to 600 hp ,10seconds,1.5 60ft on slicks
PostPosted: Fri Jun 10, 2011 8:33 pm
i pulled a x member out of a 92 plymouth vista wagon awd auto. there is no rear mount on the block its on the rear of the trans. ill grap a pic later.
PostPosted: Fri Jun 17, 2011 9:14 am
Are you sure this was a '92 and not a '93 made in late '92?
A true '92 vans would have been made between late summer of '91 through early summer of '92. They would also have a 6 bolt motor.
PostPosted: Tue Jun 21, 2011 12:08 pm
Ive seen this one. If you get the bracket off the trans, it might bolt up too. My trans from an importer had this bracket but I want something available here all the time. I'm sure auto and 5speed brackets are different.I'll see if I can find the one I had.Its been years.
PostPosted: Sat Jun 25, 2011 6:03 am
i have xmember with both front and rear mounts
PostPosted: Sat Jun 25, 2011 12:50 pm
Look at my awd build thread. I used the awd vista crossmember with success. And I still have a jacking point like before!
89 Original Turbo Colt Gt AWD PTE 6262 Built 9:1, TRE stage 2. 10.93@129
05 Evolution VIII FP Green, garage queen.
97 Eclipse Gsx 80k miles, 6 Bolt, HX-35
08 Ford F-350 6.4 PSD 3 mods and 600hp :)
PostPosted: Thu Nov 03, 2011 9:21 am
Anyone know how to get ahold of this guy? He disappeared :(
1990 Colt AWD 8.8
