It is currently Fri May 10, 2024 11:07 am
PostPosted: Tue Apr 20, 2010 1:48 am
As stated in the title, im looking for the factory turbo oil drain line from a 1G DSM. I also need the bolts that hold it to the bottom of the turbo and the bolts that go into the oil pan itself. I also need the oil feed banjo bolt that goes into the head and the two copper crush washers. If anyone has these, please PM me or post on here.
Thanks,
-Mike
-'92 TSi AWD - Daily driver
PostPosted: Wed Apr 21, 2010 10:50 am
I have the oil drain line and the two bolts that go to the pan. Make an offer, i can ship it or you can pick it up.
