It is currently Sat Jun 15, 2024 7:29 pm
 Post subject: why me
PostPosted: Sat Apr 10, 2010 1:25 pm
i know the answer to that question, its called e-bay, and so far every thing i have gottn from there is crap. so,what now? my oil pump, a ebay specal, well lets just say that tolorences are not that close, and the stub shaft, the other ebay part that saved me all of 15 bucks, well it to was not to spec, and now, i have a compleatly desasembled motor in my garage, the colprit, no oil feed to the stub shaft, it dryed up, and froze, cauzing my motor to just, STOP.. well lucky me my car was in front of my house at idle, around 800 rpm when it died, and i have found almost no problems any where else. however, in light of yet another set back, im going to have the motor compleatly rebuilt, right, this time, using only oem, and or high quality after market parts. im going to have the block reworked this time, and have it bored. its not in that bad of shape, the compression was ok befor but why settle for ok, lets go for wonderfull.
 Post subject: Re: why me
PostPosted: Sat Apr 10, 2010 4:51 pm
When it comes to parts like those ALWAYS go OEM! [-X Good luck on the rebuild.
PostPosted: Sun Apr 11, 2010 11:30 am
yes, the lesson has been learnd, more than once with this car. problem was, when i started i really had no idea what i was doing. iv read a lot, talked to a lot of people, and over the lat year iv gotten so much info, that i kinda new something was going to happen soon. well any way, when i rebuild the motor, it will be done right this time. oem parts, and patiants.
PostPosted: Sun Apr 11, 2010 8:16 pm
I didn't know you could get an aftermarket oil pump for these engines. Scary considered what can already go wrong with oem parts in less that stellar condition or when they are revved to the moon and back.
PostPosted: Sun Apr 11, 2010 9:07 pm
Yea, Topline stuff is bad enough but this fleabay stuff is horrible.
1990 TSi AWD 4G64, GT35R, FP 3X cams, JDM FWD/AWD switchable trans
1989 Colt GT (future 4G63T, GVR4 AWD trans welded center diff, 16G)
PostPosted: Mon Apr 12, 2010 10:06 am
yes, my post was a warning to all would be motor builders out there. you can read the books, study the manuals, but if you skimp on parts you will know. take it from me. i have waisted easy 500 bucks on cheap parts. oem would have been cheaper at this point and i would still be driving my car........unless it says its oem dont buy from ebay... spend the money on good parts, please......
PostPosted: Mon Apr 12, 2010 11:37 am
I have to say the intercoolers/piping from ebay is pretty good. but yea I would check with the seller to see if it is a namebrand part before you buy it if it isn't a intercooler or pipe. especially with dsmlink and turbos.
4g61t.com
