It is currently Sat Apr 27, 2024 7:17 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 9 posts ]
PostPosted: Sat Feb 20, 2010 3:26 pm
I have 3 pairs of front twin piston calipers. $65 shipped for one pair.
I also have (4) 609 maf's with oem plug and 5-6" of wiring $40 each shipped
PostPosted: Sat Feb 20, 2010 3:28 pm
I might need one of those MAF. Its froma 2g right?
Do you have any elantra mounts new? My dad needs one for a swap.
PostPosted: Sat Feb 20, 2010 3:31 pm
I have (2) used elantra t-belt mounts for $25 each and about (4) new ones for $45 each. Some of the mafs are from 2g's and some are from galants and diamantes.
PostPosted: Sat Feb 20, 2010 3:54 pm
Do they all come with the plug/pigtail attached?
PostPosted: Sat Feb 20, 2010 3:57 pm
Yes sir
PostPosted: Sat Feb 20, 2010 6:55 pm
I might be needing those brakes...
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Tue Feb 23, 2010 11:44 am
OK guys I've sold one set, need these other two gone. I know someone wants to upgrade their front brakes. :P
Also I still have all 4 of the 2g maf's. Shoot some offers on those before they go on fleabay.
PostPosted: Wed Mar 03, 2010 2:41 am
Noob question: Will the calipers fit on stock 1.6 knuckles and rotors? No brackets needed?
PostPosted: Wed Mar 03, 2010 10:16 am
Unfortunately its not that easy. You can either mod your front hubs which still requires pressing them out and removing the captive rotor and buying a 91/92 Galant VR-4 rotor. Then these calipers bolt right on. Here is the link:
http://www.4g61t.org/forum/viewtopic.php?f=10&t=24309
Or you can buy used GVR-4 knuckles (possiblevr4 on here has a pair cheap) and replace the entire csm front knuckle assembly and then toss on Galant VR-4 rotors with these calipers.
Either way its pretty involved but well worth it in the end.
