It is currently Mon Apr 29, 2024 9:29 am
 Post subject: motor mounts
PostPosted: Sun Jan 17, 2010 12:29 am
ok so i picked up my 94 1.8 elantra mounts from the junker a few days ago. if i remember right i needed the timing side and the rear right. well i tried to drop the motor in and no luck at all. it didnt line up with the front mount at all. i put a pin in the front one first then tried to ring the timing side in and my motor sat with the flywheel ponting at the passenger door. so i am guessing i need another front mount. is it from the same elantra i got the other mounts from? also it seems like the timing mount is really close to the core support, like less than 2" away. is it suposed to be that close. will there be room for my exhaust and turbo... well i guess there would have to right its been done befor. any way any help with the front mount would be gret. thanks, Benjamin
 Post subject: Re: motor mounts
PostPosted: Mon Jan 18, 2010 1:39 pm
This pic might help:
the timing mount is very closr.
PostPosted: Mon Jan 18, 2010 5:50 pm
wow, that sheds some light. it is very close. thanks that makes me feel a little better.
