It is currently Sun Apr 28, 2024 9:20 am
PostPosted: Sun Jan 10, 2010 11:41 pm
Here are some items I collected for the new Colt project:
What do you think would be best for a daily driver and still occasionally dust a few RS4s and
Z08s?
It still needs to handle and I'm concerned the 4g63 will be too heavy on the c10 front end.
opinions welcome.
Options:
Built 4g61t
4g63t
evo III
2.3 stoker
TRE Stage II KM210 Trans
Galant VR4 Motor
PostPosted: Mon Jan 11, 2010 1:58 am
I say go with a good ole 4g63t. I honestly can't see how it could be that much heavier than a 4g61t, if at all.
2.3 stroker will be ridiculous in a small car like that, you'll never get traction, you'll make it into a useless car.
EVO III motor isn't going to bolt in unless you do custom everything.
PostPosted: Mon Jan 11, 2010 2:01 am
Everything Tony said, I agree with. I just want to add, that is a fine looking transmission. Was a little curious what you picked it up for, actually.
Good stuff - trucks bring it!
PostPosted: Mon Jan 11, 2010 12:09 pm
I think I agree. I'll sent the VR4 motor out to Bushur soon.
4G63it is!
The transmission was rebuilt by John at Team Rip and includes
The parts replaced:
New front differential spider gearset
New high friction 1-5th synchros
New 1st-2nd hub & sleeve
New 3rd/4th hub & sleeve
New 1st-2nd shift fork
New 3rd/4th shift fork
New double synchro 2nd gearset
New Input shaft bearings
New Intermediate shaft bearings
New needle bearings under 1st -5th gears
New oil seals
New synchro keys
New synchro key springs
New front differential shims
Neodymium trash magnet, oil filter and magnetic drain plug.
New snap rings, heavy duty double roll pins, end nuts, bearing shims and all the other non-reusables
All gears & shafts stress relieved, deburred and modified for durability and improved shift quality.
Glass beading of transmission case.
"Rip Grip" Limited slip insert
All for about $1100.00
PostPosted: Mon Jan 11, 2010 4:27 pm
that thing is sweet. i need a tranny sooooo bad right now its killing me. nice work on that thing though. when or should i say if i ever go back to work in our ever falling economy i would like to have a good tranny built myself. good luck.
PostPosted: Mon Jan 11, 2010 4:51 pm
Did TRE put in a new shift shaft seal on your trans? Sometimes they don't do that and it will leak!!!! (I am just pointing out my experience with TRE's tranny rebuild). Just a heads up for you before you put the tranny back onto your car.
______________________
PostPosted: Mon Jan 11, 2010 8:54 pm
That sounds like an awesome deal on all that tranny work. Have fun with the project and keep us posted.
PostPosted: Tue Jan 12, 2010 11:19 am
Hey Deco,
I've a trans you can have, I bought it from someone one this board. I was told it was good. It has
no markings, but looks like a KM210 but with a more modern bar code label on it. It might be
out of a newer Hyundai Elantra? If you want it you are welcome to it!
-John
PostPosted: Tue Jan 12, 2010 11:37 am
Hey Deco,
-John
If Deco doesn't take it, I would be interested in it. I would gladly drive up there and take it off your hands.
PostPosted: Tue Jan 12, 2010 4:55 pm
hell, wow thats outstanding... i would love to take that thing, thanks. only problem is im not all that close. shipping it would probably be like 100 bucks right. well if your willing to ship it let me know how much to 89131. im really just sitting here waiting on a tranny so i can really get the motor in, and fitted right. thanks again, Benjamin
PostPosted: Thu Jan 14, 2010 11:23 am
Either of you are welcome to it. I'll take some pics of the trans this weekend and you can decide if you want it or not.
-John
PostPosted: Thu Jan 14, 2010 1:59 pm
for me its not a question of want, its need. if you lived next door id already have it. but were there is a will there is a way so let me know, i may head to bakersfield this week end and if so maybe i drive a few more hours northwest. who knows. thanks, Benjamin
PostPosted: Sun Jan 17, 2010 11:06 am
hey 874g61t what mounts did you use in your original swap cause deco could use some help
PostPosted: Sun Jan 17, 2010 2:28 pm
I believe I used:
Timing mount: 89 Turbo Colt (C50)
Front mount: 87 Turbo Colt (C10)
Rear mount 92 Elantra (One bolt hole needs to be modified) Contact me or Mirageist before you do this.
Trans mount: Maybe Turbo colt. Possibly 1/2 (trans side) Turbo Colt. 1/2 (chassis side)
87 Turbo C10. But I believe it was a Turbo Colt mount ( both Halves)
I'll thing more about it and get back to you.
-John
PostPosted: Mon Jan 18, 2010 8:49 pm
Deco and Cap'n
Here are some pics of the km210 Trans. It is a 210 but may be not from a colt.
