It is currently Sun May 12, 2024 1:49 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
PostPosted: Fri Oct 30, 2009 11:49 pm
GVR4 sunroof $50 (whole assembly)
GVR4 headliner for sunroof car $40
GVR4 stock intercooler piping with intercooler and stock intake pipe $50
GVR4 passenger side seat Complete, will sell 1/2 if needed $40
GVR4 headrest for driver side $10
GVR4 rear subframe with 3 bolt includes all hard lines, rack etc.. will split up $100
GVR4 wing, and rear emblems from a 92 (not in tailights) $75 or seperate if wanted
DSM awd trans for a core to rebuild $150
4 bolt axle cups only $40 I have 5 of these so I'll sell just one if needed
92 eclipse sideskirts $40
92 eclipse tailights red paint stripe $30
4g63 starters $15
7 bolt block with bad crank (spun rod bearing) $50
2g ps pump, ac pump, alternator $25 each
7 bolt running motor, still in a car running/driving going to swap a built 6 bolt this winter (local preffered) $750
92 hood red, damaged ears local only $10
22 spline tcase x2 23 spline x1 and automatic tcase x2 $120 each
91 6 bolt turbo motor did run, I suggest a rebuild its been a long time since its been used~ $600
4g63 n/t block $250
n/t block and head $400
1.5 liter colt cable clutch transmission $100
Galant gsx/Expo?? awd 5 speed transmission and tcase $150
1g awd auto transmission core for rebuild slipping gears $150
F5M33 fwd turbo trans but broken mounting hole $50
FM3838 1.6 turbo mirage transmission and flywheel $250 works
1.6 hyundai elantra transmission
1.8 elantra motor and transmission
2.2 honda accord non vtec block 150 ish k miles runner $200 1994
1998 hyundai tiburon sohc engine and transmission runner/shifter $250
I have lots and lots of other parts available this is just the stuff I moved around today and wrote down.
Thanks again..
PostPosted: Fri Nov 06, 2009 12:51 am
ttt
PostPosted: Fri Nov 06, 2009 7:06 am
Would you be willing to part the 1.8 DOHC head from the block?
I would just need the head. NO other acessories to keep weight down.
PM me if so.
38654, Olive Branch, MS
Errol
PostPosted: Fri Nov 13, 2009 12:35 am
Yes. Is $100 plus shipping a fair enough price? Email thedsmguys@gmail.com
Paul
PostPosted: Fri Nov 20, 2009 12:01 am
I guess its not a fair price..
PostPosted: Fri Nov 27, 2009 9:21 pm
can i get a shipping quote on a good starter CA 94558
PostPosted: Wed Dec 16, 2009 5:50 pm
Bump. Please email me directly at thedsmguys@gmail.com I check that hourly as this is only weekly...
I also found the other day a turbo csm intake and air meter..
Tons and tons of other stuff. Sorry I'm to lazy to list it all.
Starters are around $40 shipped
PostPosted: Mon Jan 04, 2010 10:32 am
Hey. Friendly bump. If its a 1g DSM part I pretty much have it. Email me and I'll ship it out asap!
PostPosted: Mon Jan 04, 2010 7:37 pm
need a lower timing cover. been looking over having a hell of a time. can you help me out
PostPosted: Sat Jan 09, 2010 3:48 am
I never seem to have enough good ones of these. Your best bet might just be the dealer, then you know its nice and minty.
