It is currently Tue Jun 04, 2024 6:23 pm
Post new topic  Reply to topic  [ 61 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Thu Jul 09, 2009 5:49 am
those N/A 99-01 cobras are hit and miss. two of my buddies owned 99s one outran corvettes the other couldnt beat my probe gt turbo on 12psi haha. in any case thats a nice driveway of cars!
PostPosted: Thu Jul 09, 2009 9:57 am
The 99's had a massive recall because they were way underpowered--something about the intake manifold not being properly designed. I think they were making like 240hp when they were supposed to be up over 300. So awesome.
PostPosted: Thu Jul 09, 2009 10:39 am
Haha yes my buddies know all about that. They had to acid hone the intake manifold in other words port the shit out of it and did something with the mufflers and ecu. Stock crank hp was supposed to be rated at 320. Usually the basic intake, exhaust mods made 295-305 wheel hp for those years.
PostPosted: Thu Jul 09, 2009 4:49 pm
Digital Baby Troll
The 99's were rated at 320hp crank but usually could only put out around 240-250hp in private testing. Lil is an 01 which I believe were rated at 350hp crank and tests brought back 370 private. I'm guessing when I first got the car it was around 250-260 wheel which isn't super bad at altitude. I put a lower set of gears in it, new mufflers, and removed the rev limiter and had the speedo reset for the new gear ratios. Now I feel I'm around 300-310whp, but one things for sure pulling 60-85mph in 2nd gear at 8,000 rpm with a V8 is a thrill and scares the shit out of most anyone. I need a full exhaust system and intake for her though, but first I'm gunna get the shitbox be out run her. Though the Mirage will never out handle the Cobra, that thing rides on rails.
-John
PostPosted: Thu Jul 09, 2009 10:47 pm
99-01 cobras had the same driveline and were both rated at the 320 crank hp. it wasnt until 03-04 when they came supercharged that they bumped hp up to 390.
PostPosted: Fri Jul 10, 2009 3:19 am
Digital Baby Troll
Called out on my own car, never really took much interest in this one so I never really took the time to check the specs and all. I just knew it was pretty quick, comfortable to drive, handles like a go cart, and would be a total chick magnet. Girls aren't really attracted to the shitbox. I could have sworn they changed something between the 99 and 01's but I guess not. Thinking I may rebuild its motor at some point and try putting twin turbo's on it, but I would probably get into trouble way to fast, I do dumb things with rwd vehicles.
-John
PostPosted: Fri Jul 10, 2009 8:53 am
-John
Yeah the N/A 32 valves have gone super fast with just simple bolts on and spray. Only thing that sucks is the factory pistons are hyperpetrunic I think its called and are weak so they don't like boost on stock motors. If you get that thing built with a big single turbo setup and supporting mods it will be the lasts sports car you'll want to buy haha
PostPosted: Fri Jul 10, 2009 10:04 am
Hey John that turbo is not a 11b, it's a 13g. The engine you bought is from an automatic car. It's got 390cc injectors and a 13g turbo. They still say TD04 on them and they look similar to the 11b but they are slightly larger.
PostPosted: Fri Jul 10, 2009 5:35 pm
Digital Baby Troll
Yeah I noticed that the compressor wheel was different than my 11b but it still came with the 450cc blue top injectors. Maybe after market, I've found a few weird little tweaks done to the motor.
PostPosted: Fri Jul 10, 2009 5:39 pm
Digital Baby Troll
-John
Yeah they designed the pistons to be super light so the car would build rpm's faster but they'll melt down real quick if you put a forced induction system on it. The thing already scares me sometimes so a turbo set-up would be fun if I decide to re-build it.
PostPosted: Sat Oct 17, 2009 2:13 am
Digital Baby Troll
Back in the game. I finally got off my mourning ass today and got some work done on the shitbox. I dropped the transmission a week ago and finally got the axles back today from getting them re-built. The guy did an awesome job and actually used to race a turbo mirage, so he knew what he was dealing with. Today I was able to pull all the wiring off the motor, got everything marked and labeled so I don't confuse myself when the new motor goes in. I also did the whole EGR/vacuum delete deal, this way I don't have to worry about the Cyclone intake giving my a hard time. Finally I was able to install the manual seat belts, all the mounts were there besides the lower ones which I just welded up a cheesy little mount for. I'm hoping to get the old motor out tomorrow then start finishing the prep work on the new one. If all goes well she should be fired up in a week or two at the longest. Wish me luck.
-John
89 Mirage Turbo-Money pit
99 Jeep Cherokee-1/4 Epic
01 Cobra-Too Thirsty
72 Dodge-Pedo'van
PostPosted: Sat Oct 17, 2009 8:38 am
\:D/
PostPosted: Mon Oct 19, 2009 9:28 pm
Digital Baby Troll
Update: Finally got the old motor out, turned out to be really easy once I just took it one step at a time. If all goes well I should have the new motor in and fired up by the end of the week.
Weight reduction :lol:
-John
72 Dodge-Pedo'van
PostPosted: Thu Oct 22, 2009 12:56 pm
Your suspension looks familiar to me :lol:
Good stuff - trucks bring it!
PostPosted: Thu Oct 22, 2009 5:55 pm
Yep, and then it's back on with the blue wheels... :rolleyes:
