It is currently Tue Oct 28, 2025 5:15 pm
 Post subject: fuel lines in a 63 swap
PostPosted: Thu May 07, 2009 6:46 pm
so the car is running again but it builds up mad amounts of presure in the tank. when I open the filler cap to add fuel theres a big gush of air .... when you guys do the swap...what do u do for fuel lines?
I used the stock feed and replaced the filter...and im useing the stock return also...when I take the return line off it feeds back alot of fuel...theres also a 3rd line that is also there that is not hooked to anything...has anyone else had this problem?
and yes it is the correct return line i didnt take them off the car.and car ran when I got it...
thanks
PostPosted: Fri May 08, 2009 6:22 am
That third line is the vent line; did you clamp or crimp it off? My buddy crimped his and his car will do that every time. It is vacuum caused by the tank being sealed and the pump forcing out fuel. It should be open and able to easily vent to the atmosphere or your charcoal can.
PostPosted: Fri May 08, 2009 11:41 am
yeah its just hanging there opened.....so this is nothing to worry about then?
PostPosted: Fri May 08, 2009 11:49 am
No. If you are still getting tons of vacuum then there is a problem with the vent line. It may be clogged.
PostPosted: Tue Jun 30, 2009 4:46 pm
so I got the car running again for the 4th tims since march... and the damn fuel line that goes from the filter to the rail has a hole it in and is leaking really bad... when I go to purchase a new one do I get it for the colt or for a dsm?
thanks
PostPosted: Tue Jun 30, 2009 5:12 pm
Colt.
PostPosted: Tue Jun 30, 2009 5:21 pm
kewl ty.. now would it be the 89-92 only or will a 93-95 work?
PostPosted: Tue Jun 30, 2009 7:43 pm
Prebent lines from autozone? You'll want the 89-92.
PostPosted: Tue Jun 30, 2009 11:55 pm
they told me its a dealer item only.. dealers cant even get them so I cut mine and put a steel braided line in there untill I can get the fittings and do it correct.. but it works for now.. thanks for the help.
