It is currently Mon Jun 17, 2024 5:22 am
 Post subject: 4 bolt rear end
PostPosted: Fri Mar 20, 2009 12:55 pm
if i want to up my 3-bolt rear end to a 4bolt, if i cant find a 92-94 1g 4-bolt rear end is it possible to use a 2nd gen rear end?
also what are all the parts i will need to collect to convert it to a 4bolt rear?
 Post subject: Re: 4 bolt rear end
PostPosted: Fri Mar 20, 2009 1:49 pm
No, a 2g rear-end is totally different, doesn't use axle cups and flanges like a 1g rear-end, the axles goes straight through the hub.
PostPosted: Sat May 02, 2009 3:46 am
unless your making alot of power i'd run the 3bolt until you bust it. just my 2cents
