It is currently Mon May 13, 2024 5:03 pm
PostPosted: Fri Mar 06, 2009 3:35 pm
Color matching is awesome :D
PostPosted: Tue Mar 10, 2009 2:10 am
What paint did you use to paint all your stuff? And what oven temp and time length did you do when you baked the parts? They look good!
PostPosted: Tue Mar 10, 2009 3:04 am
Here's a link.
http://www.vhtpaint.com/flameproof.html
I used VHT's FlameProof coating in a rattle can and followed the directions on the can for oven curing. I started with three light coats(each coat dried before applying another) of the SP100 flat grey primer and then I used three light coats of the SP117 flat aluminum. I did not use the clear because I was trying to match the manifold up to my FP intake tube and it came out very close without it. I went exactly by the instructions on the can and used my oven to cure the pieces( my oven only went to 550F). A couple of tips I have would be to warm the cans up in hot water before use so the spray would come out easier and to use very light coats. I did all the parts you see with just one can of primer and one can of flat aluminum and I still have at least half a can in each left. Not sure how much they will be for you but I picked them up at local autozone for about 8 dollars a can.
PostPosted: Wed Mar 11, 2009 1:47 am
Just got my head back yesterday, looks like I'm goin to be doing a lotta work this weekend! I should have some pics of the install Monday night.
PostPosted: Wed Mar 11, 2009 7:39 pm
Nice :wtg: Can't wait until you get this up and running so I can get some feed back from you to see if I want to use my HX35 turbo.
PostPosted: Fri Mar 13, 2009 8:31 am
me to i have a mint hx35 right now. just want to hear from you if its worth swapping to the bulls eye housing.
PostPosted: Fri Mar 13, 2009 9:32 am
Good luck with that paint, it will probably burn off even though you took the proper precautions by curing it. I used the same stuff on my exhaust manifold, but in black, and it didn't last too long. I cured it in the oven as well.
PostPosted: Mon Apr 06, 2009 6:46 pm
update: I've been workin a lot lately and it seems every day I have off its either very cold or raining(dont have the luxury of garage) but I did bare the cold a day or two and got my lsd insert installed, the motor back together and the motor and tranny back in the engine bay with the new poly mounts. All I have left now is to make some mounts for my new radiator set up, put the manifold and turbo onto the car and install the axles. Not sure what to do about my IC pipes as they dont have rolled edges. I do have really good couplers and t bolt clamps, Im hoping they wont pop off, cause I would like to try and get it up to 25lbs. Oh by the way I went with a Honda type radiator, I have not seen anyone run this type yet it is a 3 core rad that is 350mmx385mmx60mm its the same height as any other but a little wider a way thicker! :wink:
PostPosted: Mon Apr 06, 2009 8:12 pm
might wanna give this a try with the intercooler pipes.... http://www.dsmtuners.com/forums/article ... pipes.html
PostPosted: Tue Apr 07, 2009 10:20 pm
some progress today, it was freezing cold out but I got few things done. Did I mention it was freezing out, and to top that the wind was blowing in from some far off artic tundra and decided to flurry a time or two. I love the weather here. :D
lol, I need to swap out t stat
housingImage
PostPosted: Thu Apr 09, 2009 12:07 am
Wow, that radiator really is thick! Where did you buy it from? :o
PostPosted: Thu Apr 09, 2009 6:02 am
EBAY BABY! http://cgi.ebay.com/ebaymotors/Honda-Ci ... enameZWDVW
PostPosted: Sun Apr 12, 2009 9:54 pm
It Lives! Got her running tonight, I will be posting pics of the finished set up as soon as I can. I will also be filming a couple small vids of some pulls and what not, just need to get a good video cam or find someone with one. Joey
PostPosted: Mon Jun 22, 2009 10:45 pm
So its been a couple months now and the cars running awesome, but I have come to a croosroads and kind of in need of some cash. I'm not sure what a good asking amount is and the only weak part of the car is the exterior(paint and few dents) and bad seats. I really would like to convert it to AWD, but that seems better suited for a base model rather than a original turbo GT. I really fell in love with this car since the first day I drove it, even with a raggedy 1.6 and smokin 14b. This is kinda a gauging interest thing, lookin for some advice.
Thanks Joey
Here's a mod list (most parts have less than 1k on them including motor)
4g63t,
1g rods/2g pistons
balance shafts removed,
Delta 272's,
ARP Headstuds,
fmic,
Custom 2.5" intercooler pipes,
Tial Q bov,
2g throttle body elbow,
SBR MBC,
Holset HX35 w/BEP Bolt Housing,
FP Race manifold,
Custom O2 with ext. wastegate,
Turbonetics Delta Gate II,
Megan 3" downpipe,
3" Catco, 36" resonator, greddy evolution muffler,
Aeromotive FPR and gauge,
rewired Walbro 255 fuel pump,
PTE 680cc injectors,
3" GM MAFT blow through,
Socketed JDM VR4 Eprom (converted to USDM),
AEM uego wideband,
Greddy turbo timer,
relocated battery,
12" slim fan,
magnecor plug wires,
Front and Rear Poly mounts,
AEM wideband,
GM MAFT,
DSM Link V2.5,
autometer Z Series boost gauge,
1g fwd tranny w/lsd insert
ACT 2100 pressure plate,
OEM clutch disk,
Brass shifter cable bushings,
polyurethane shifter base bushings,
KYB GR2's,
Eibach pro kit springs,
original white EVO lll OZ wheels,
Yokohama Advan A043 tires
PostPosted: Tue Jun 23, 2009 10:16 am
Sell me your DSM Link... I need it! :D
