It is currently Sun Apr 28, 2024 7:01 pm
 Post subject: Colt went to the track
PostPosted: Tue Sep 09, 2008 8:45 pm
I took my Colt Gt to the track the other day. My setup is a built 2.3L w/comp cams, fp18g, 2" pipe, 3"exh, 2g maf, fic 750s, dsm link, phantom grip lsd, m/h 23x7.5x15, 18psi, km210. My setup is pretty new so i havent had much run time for break in. i had a boost leak that was beeding off to 15psi and trans no longer seems to shift well. It ground into 2nd every pass and had to shift 3 and 4 slow not to miss. It was frustrating to shift that slow. 60' 1.82 330' 5.534 1/8 8.32 mph 89.84 1000 10.78 1/4 12.81 mph 113.4
PostPosted: Tue Sep 09, 2008 10:14 pm
A 2.3 with an 18g, must be responsive. Got any pics?
PostPosted: Tue Sep 09, 2008 10:28 pm
I'll get some pics up soon. It is pretty clean for a northeast car. spools up quick. It was funny how fast that motor spooled the 14b crusin around when i put my beak in miles on it last fall.
PostPosted: Thu Sep 11, 2008 1:16 am
Sounds like a good setup....minus the grindage, of course!
PostPosted: Thu Sep 11, 2008 2:39 pm
Get a twin disc. Pull the tranny apart and swap the 1st and 2nd gear syncros. Problem solved!! :)
If I had a dollar for every V8 beaten by a colt I would be a millionaire. But I would still be driving my colt.
PostPosted: Thu Sep 11, 2008 9:50 pm
Who makes a good twin disc setup? Does that require a flywheel change too?
PostPosted: Fri Sep 12, 2008 4:49 am
GSX is using a Quatermaster right now. Seems to work well. That is what I will be using when my car is back together.
PostPosted: Mon Oct 27, 2008 9:24 pm
Well, about 3 weeks ago i decided to put an act 2600 clutch in my car. As soon as i finished, i loaded the car and went to the track. First pass out, it went 12.4 @ 115.7 1.83 60'. 2nd pass was 12.6 @115.6 1.74 60' shifting not as good. 3rd pass i broke the diff., put a hole in
the case and oiled the track. SUCK. back on the trailer.
So i went home, pulled the trans, and took it apart. A few days later, a friend of mine gave me another km210 to use. I Took that one apart and put my steel 3-4 fork and lsd insert in and put it back together.
There was a mopar day at my local track Sat. so i wasnt gonna miss that. Alot of cars showed up but no vipers or fast fwd cars to race. mostly rwd muscle cars. The track cond. was good though. boost was at 20psi. half 93 octane half c16.
First pass
1.78
5.43
8.23
85.72
10.59
12.53
117.65
second pass
1.73
5.17
7.89
88.39
10.23
12.16
119.93
third pass
1.70
5.19
7.87
88.18
10.17
12.07
120.87
fourth pass 1st round elim. missed 2nd
1.72
5.69
8.52
67.77
10.89
12.84
118.58
last run was 12.38 @118.74. Kinda wanted to break 11s but i was happy with the day. Had the fastest pass to date and best 60' time too.
PostPosted: Mon Oct 27, 2008 9:47 pm
Wow man, those are some pretty decent times. 120mph on an 18g is pretty impressive.
How much does the car weigh?
PostPosted: Mon Oct 27, 2008 9:51 pm
I checked it at the track sat. Weighed in at 2520 with me in it.
PostPosted: Mon Oct 27, 2008 9:52 pm
Nice, whats your technique on launching the car with the m&h and whats your tire pressure?
PostPosted: Mon Oct 27, 2008 10:02 pm
I set them at 9.5 psi after they were warmed up on my first pass and didnt touch them the rest of the day. I've had the best 60' by bringing the rpm up about 5000 to 5500 and just rolling it on as i let out the clutch with a little preload sometimes. the launch control was at 5500 but i've been stayin off that cause it gives a little more wheel spin. oh and i usually try to do a decent 2nd gear burnout to get em hot
PostPosted: Tue Oct 28, 2008 9:24 am
Wow, so close to 11's. You must be stoked. Great job!
PostPosted: Tue Oct 28, 2008 4:43 pm
Thanks. I was pretty excited after the 12.0 pass. Im going to build a tranny this winter to get some consistent shifting. havent decided if i should do the km210 or go to a 1g dsm. Any input would be appreciated.
PostPosted: Tue Oct 28, 2008 11:19 pm
I would go ahead and use the 1G FWD transmission because of the longer gears. Also, I would because you have a 2.3L.
