It is currently Sat Apr 27, 2024 1:03 pm
Post new topic  Reply to topic  [ 123 posts ]  Go to page Previous 13 4 5 6 79 Next
PostPosted: Sun Aug 24, 2008 8:25 pm
alrighty kids more fun today.
well now, looky what i found on my porch !! i love how the fedex guy just knows what i need.
started building some brackets for mounting.. i toggled back and forth about how to mount this thing and finally settled on right here, it just wasnt gonna work out any other way..
its off to the side so there is room for my battery box.. and maybe a nitrous bottle or two..
see!
so i started on making my fuel lines. i was expecting to totally screw this up, but it went perfect! i didnt screw up one cut or mangle one AN fitting.
i needed a spot to mount that fuel pump so i started making some brackets. im about tired of making custom stuff... haha
tacked it up there..
hopefully this guy isnt allergic to ethanol cause he will be seeing alot of it.
thats it for now... and you thought this was gonna be easy.
PostPosted: Sun Aug 24, 2008 8:26 pm
nice, what kind of fuel cell and pump is that?
PostPosted: Sun Aug 24, 2008 8:34 pm
looks like a RCI cell, and a Aeromotive A1000 pump ???
hope you add the rest of the fuel cell bracket for support..
scot
PostPosted: Sun Aug 24, 2008 8:39 pm
aluminum cell is questionable for e85, its not hard coated, just raw material. I thought about the same cell, but went with a poly one since E85 is in the future. Also not to put your fuel system down, but if you are considering E85 the feed line should be a AN-10, with a An-8 return. The Aeromotive pump is ok for E85 also, Filter is a little small..
sorry,
scot
PostPosted: Sun Aug 24, 2008 8:41 pm
Little off topic but dont you need to change out the rubber fuel components to run e85?
PostPosted: Sun Aug 24, 2008 9:04 pm
there are more mounts and brackets under there i just didnt take pics of everything. and everthing is still in the mockup stage anyways, i dont think there is a single bolt on the car thats tight.
and yes its the A1000 pump but i believe the cell is a summit brand aluminum cell.
i didnt realize the filter was so small when i ordered it i'll be switching it out shortly
i figured they protected those cells so they could be used with any fuel.. ehh we'll see what happens. i think -8an lines will be ok for what i wanna do
PostPosted: Sun Aug 24, 2008 11:01 pm
:o That's tight, that's what I want for my awd hyundai project, great work, looking good :D Also how many gallons tank is that?
PostPosted: Mon Aug 25, 2008 8:47 am
thanks man..
its a 10 gallon tank.
PostPosted: Mon Aug 25, 2008 8:59 am
Awesome project! Good job!
Just one thing about the tank, are you planning to build an enclusure around it? You need a fire-wall between you and the fuel tank (most tracks are very strict about it). That is why people usually put them under the floor (at least partially, so that you do not have to build as big of an enclure).
But you probably knew this ;).
PostPosted: Mon Aug 25, 2008 11:14 am
yes sir i knew that.. luckily we just got a new metal bender to build me a snazzy enclosure. i was hoping to not have to do this, but it just didnt work out like i planned.
thanks for lookin out.
PostPosted: Mon Aug 25, 2008 11:22 am
pictures! lol
PostPosted: Fri Oct 10, 2008 8:16 pm
Where are the updates on this bad boy?
PostPosted: Fri Oct 10, 2008 11:39 pm
i wasnt sure if anyone cared so i havent been posting much
the only thing left is the driveshaft and it will be driveable.
i still gotta enclose the fuel tank and weld in the cage but im firing it up sunday, hope the neighbors get to church early.
PostPosted: Sat Oct 11, 2008 9:43 am
I was following this thread because you were doing an awesome job. I always looked forward to the updates.
PostPosted: Sat Oct 11, 2008 10:25 am
Have you experienced any issues with diff location? That rear diff brace looks to be sitting too "high" up in the car.
Users browsing this forum: No registered users and 128 guests
