hey bud that pic isnt working for me. just got a red x.
i made sure (after reading posts here) to double check the location of the tires in the wheel wells before welding it in so it wasnt to far back or forward.. i think it looks straight.. heres a pic.
as for the pipe you cut and welded, can you explain better what your talking about? i have the holes from the stock talon struts welded to the stock CSM mount holes like a figure 8 to give the right height but the camber of the wheels makes the top rub on the bottom of the spring just like yours. i can pull the shock away from the tire enough to clear but then i couldnt get it welded right it would be offset
i've seen people use stock talon wheels so im hoping i didnt over look something stupid...
![:-?](./images/smilies/icon_confused.gif)
