It is currently Mon Oct 27, 2025 7:21 pm
Post new topic  Reply to topic  [ 25 posts ]  Go to page Previous 1 2
PostPosted: Thu Dec 20, 2007 6:04 am
so what is the gray box that they plug into?? I like the info and am interested in this for fewer problems later.
PostPosted: Thu Dec 20, 2007 8:07 am
not really a gray box, but the wire harness connector for the injectors.
4g61t.com
PostPosted: Fri Dec 21, 2007 1:00 am
mmk that totally loses me, i will have to do a bit more research into this and get back to some more questions later. need to get the swap done first, then i can worry about this. sooo much to do so little time! Thanks for the awsome help with all the wiring diagrams though. I printed most of them off to try and help. :)
PostPosted: Fri Dec 21, 2007 5:09 pm
I've got 4 cop's sitting here, now I've got to get the wiring done up and a plate made.
PostPosted: Sun Dec 23, 2007 3:48 am
also old maximas had cop just fyi
95 tsi awd- 13.78
PostPosted: Wed Aug 20, 2008 4:27 pm
Digging this up...
I've got 91 electronics and switched to a COP. How do I make my tach work with it?
PostPosted: Wed Aug 20, 2008 7:02 pm
My buddy actually builds these and sells them. They look awesome but to tell you the truth i didnt notice any difference on his car.
 Post subject: cop
PostPosted: Wed Aug 20, 2008 9:54 pm
How abt dyno the stock, then dyno the cop and see if there is a difference. I don't care what the old assomitter tells you. As long as you use the same dyno you will actually see a difference.
PostPosted: Thu Aug 21, 2008 7:39 pm
I didn't feel a difference but the car sounds a tiny bit different down low+at higher rpms. It cleans up the engine bay/eliminates any kind of coil+plug wire problems/looks badass.
PostPosted: Fri Nov 28, 2008 9:10 pm
I have a busted 2.7 in the corner of my shop waiting to be scrapped. It has six of those coils on it that work fine. Would I really need to use an MSD box to run them? I think I have one of those lying around somewhere too, but I really think it works better sitting on a shelf than on a car.
