It is currently Sun Apr 28, 2024 10:54 pm
 Post subject: Rear Toe
PostPosted: Fri Feb 21, 2003 1:39 am
Is there any way to adjust rear toe? The manual says you can't. Are there any aftermarket parts that let you do it?
 Post subject: Re: Rear Toe
PostPosted: Fri Feb 21, 2003 1:57 am
Don't our cars have solid rear axles, not IRS. The onlyway i could think of is to cut the ends off and weld them back at the angle you want. Just a thought.
The resurrection begins.
90' Plymouth Laser RS Turbo (donor)
90' Dodge Colt (2.3L 4g63T swap)
PostPosted: Fri Feb 21, 2003 8:53 am
Yeah it is, but on some cars you can add spacers in the hubs to get toe and/or camber. Just wondering if it was an option on ours.
 Post subject: I guess you could....
PostPosted: Fri Feb 21, 2003 4:43 pm
Though my first thought was no, I was thinking you really could if you wanted. I guess you could add a thin shim washer behind the hub (bolts on with 4 bolts on the disk axle anyway) on the back two bolts. What I think is a better option is to make a thin (about 1/8") plate that is angled at your desired toe in. The shim washer would leave a gap and not fully support the plate, thus putting a lot of pressure on the bolts, the plate shim would help distribute the load.
I am not sure why you want to , but this should work reliably.
Chris
