It is currently Mon Apr 29, 2024 3:24 am
PostPosted: Thu Nov 08, 2007 1:08 pm
Finally took the colt to the track last night. It was really cold out here in new york, like 45 or 50. So no traction...
Set up: 660's, 60-1,fmic 2.5 piping, 2g mas, 3 inch pipe,272 and 264 hks cams,93 octane,18 psi boost on dragradials.
First run:
60 foot: 2.128
1/8: 8.689
1/4 mile: 12.91
mph: 117.81
Dragradial 15 psi
2nd run:
60 foot: 2.348
1/8: 9.007
1/4 mile: 13.267
mph: 116.89
13 psi
Final run:
60 foot: 2.186
1/8: 8.513
1/4: 12.749
mph: 116.47
10psi [/list]
PostPosted: Thu Nov 08, 2007 3:48 pm
1595 cc's of fury
Not bad at all for pump gas and DR's. I could also only muster a couple 2.1x 60's on Nitto DR's at 13 psi. Temps were around 55 degree's also.
PostPosted: Thu Nov 08, 2007 5:48 pm
good times. Now get slicks and race gas and lets see some mid to high 120 traps.
PostPosted: Thu Nov 08, 2007 6:28 pm
Thanks guys... Im thinking on getting slicks, but i want to used my vr-4 wheels. Dont know what size slicks will fit.
PostPosted: Thu Nov 08, 2007 8:11 pm
Ditch the VR-4 wheels. They're small and heavy, which is a bad combination. Pick up some cheap Rota Slipstreams or something to put slicks on and use your VR-4 wheels for daily driving.
PostPosted: Thu Nov 08, 2007 8:38 pm
So what size slicks i could used? My friend used 24.5 by 8. Will da work?
PostPosted: Fri Nov 09, 2007 12:32 am
1595 cc's of fury
M&H 23 x 8 x 15's work really nice and are the same diameter as stock, keeping your gearing lower. The 24's like to rub your struts over 100 mph.
PostPosted: Fri Nov 09, 2007 3:18 pm
Reminds me of my old whip 4 years ago.
22 or 22.5 inch tall tires worked best when I was at your trap speeds...
Current
08 535ix 420awhp
06 C6 Z06- 600whp NA
PostPosted: Thu Feb 14, 2008 12:06 am
horrible. 60ft time need help. M/T radial are suppose to be great. it has zero thread wear rating. you will need a lot of back space with 24X8 slicks to clear the strut. coil over will fix this problem. my best 60ft time on slick is 1.63s with stock strut and spring. you will need to put the pressure at 16psi. i think it will get quicker if i have lsd. your car is making the power with that mph so you should get some high 11s with traction.
PostPosted: Sun Mar 23, 2008 3:19 pm
You should definatly be able to get a better 60'. I pulled quite a few 2.1x's in my base model 4g61t'd car on 195/50 15" Sumi HTRZ's. I would think 1.9-2.0s on DR's.
PostPosted: Mon Mar 24, 2008 8:50 am
Coil overs + 24.5 X 8 + Quaife are what you need :twisted:
PostPosted: Fri Sep 05, 2008 11:46 am
Let's see what happens now. Upgrades... Coilovers, sheptrans (stage2) and 24.5/8.15 M.T slicks. Just not sure if is going to hit that strut, but im getting 1/4 spacer and bring that car all that way up on front. Now lets see what happen..........
PostPosted: Fri Sep 26, 2008 9:49 pm
Ok. I when to that track again, not too happy cause i was having problems with the stutterbox. I only got to run 2 times since that car didnt want to rev past 5000rpm.
First pass.
60 foot- 1.918
1/8- 7.924
1/4- 11.957
mph- 121.54
On slicks.24.5/8/15. 9psi
second pass.
60 foot- 2.397
1/8- 8.623
1/4- 12.654
mph- 120.41
PostPosted: Mon Sep 29, 2008 4:29 pm
Check the connection on the wires that go to the clutch pedal switch. I had a similar problem in my car (wouldn't rev past 5500rpm), and it was because the wires to the stutterbox had a poor connection.
