It is currently Sun Jun 16, 2024 12:22 am
PostPosted: Wed Jun 13, 2007 8:49 pm
everyone is charging an arm and a leg for everything, new and used, awd these days. So getting awd parts from a junkyard from an eclipse is getting pricey. would the 5-speed awd summit van parts be a good solution? are they the same as the eclipse parts?
PostPosted: Wed Jun 13, 2007 9:32 pm
The awd trans parts are pretty much the same as a 2g awd, as far as suspension, they are totally different.
PostPosted: Wed Jun 13, 2007 11:37 pm
same as the 2g eclipse or 2g mirage?
PostPosted: Thu Jun 14, 2007 1:29 am
2g dsm
PostPosted: Thu Jun 14, 2007 10:00 am
An early Van, like 90-93 will use the same mounts and tranny as a 1G. I have a Summit/Expo AWD Tranny that Im putting in my 89 Mirage but using it as a FWD.
PostPosted: Tue Jun 19, 2007 7:08 pm
the 2.4 liter awd summit 5sp is the same as an 1g eclipse/talon
PostPosted: Sun Mar 02, 2008 9:46 pm
My van even though it's a 95 its has a 1g tranny and from the looks of it, it looks like a lot of 1g parts in it.
PostPosted: Mon Apr 07, 2008 11:25 am
You sure? I'm 99% positive it's a M31 series trans and is built lighter than a typical DSM AWD. (DSM=M33)
PostPosted: Mon Apr 07, 2008 7:26 pm
How about the automatic awd expos? Please let me know.
PostPosted: Fri Apr 11, 2008 11:44 am
I always thought those vans had the 2g style transmission and 2g style suspensions.
Don't they have the wideblock 4g6x engines? If so, I don't see it bolting to the narrowblock 4g6x.
:rolleyes:
PostPosted: Fri Apr 11, 2008 3:10 pm
:rolleyes:
The 92's (like mine) have the older 1g style tranny with the mounts on the engine block. The 93+ have the 2g style with the mounts on the tranny. They are also narrow block 4G63's. The D50's and Mighty Max's have the wideblock 2.4's.
The rear suspension is really nothing like a 1g or 2g. They use a coil spring and a separate shock.
PostPosted: Sat May 03, 2008 1:25 pm
I just picked up 93 AWD Summit Wagon and it has 2G style transmission mounting (motor mount on the tranny and not on the block).
These wagons came out in 92, so are you saying that they had just one oddball year (92) with 1G style tranny/engine mounting? I find this highly unlikely :shrug:
Can somene with a 92 wagon chime-in on this?
Thanks,
PostPosted: Sat May 03, 2008 1:45 pm
Yes, there was one oddball year for some reason. Mine is a 92 AWD with the 2.4. It has a true 6 bolt engine and the mounts are all on the block. The tranny only has the upper mount that mounts to the framerail. Also the timing belt mount is an "L" shaped mount like 1g dsm's use.
BTW, where did you get the 93 from? Was it Gary's?
PostPosted: Sat May 03, 2008 8:02 pm
Yes, I picked up Gary's car.
That is very strange that they went with the different engine/tranny scheme after just one year :shrug: . But I do stand corrected :oops:
I am not sure if that is good or bad for me :). I guess I would rather have 1G style tranny, as this give me more options for donor trannies (you can use ether 1G or 2G tranny).
Leon R.
99 Eclipse Spyder GST (AWD swap project)
93 Eagle Summit AWD (4G63 swap) 11.69@120
01 Isuzu VehiCHROSS (winter beater) 17.0@80
80 Triumph TR7 (4G63 swap project)
PostPosted: Sat May 03, 2008 10:22 pm
That is actually our old van. Gary bought if from us last year. My wife put about 10k on that thing driving to back and forth to work every day. After we sold it we missed it so much that we bought another one. They're not the best looking things but I love the way they drive. Plus you can haul a ton of junkyard parts in the back. :P
You MAY be able to get a crossmember from a 92 model and use a 1g style tranny. Not sure if the holes are the same or not but I agree with you. I can't see why they would change too much stuff between the two.
