It is currently Mon Jun 03, 2024 2:46 pm
PostPosted: Mon Jun 11, 2007 6:48 pm
Hey guys, first off a little background.
We are team Lemonparty for the 24 Hours of LeMons (www.24hoursoflemons.com)
We have just aqquired a 91 Mirage hatch for the race....We only have about $100 to spend on suspension (per race rules on total vehicle cost) and we really need to stiffen up our springs/struts.
I have tried installing suspension spacers & shackles into the rear of the car....but this stuff is just too damned old and the car still bounces like Captain Kangaroo
Wondering what we might find in junkyards or ebay that will stiffen up our front & rear suspension.....There's gotta be something out there!
Thanks in advance!
PostPosted: Mon Jun 11, 2007 9:29 pm
Install a used set of struts and springs from a 90-94 AWD DSM. You can also cut the front springs and that will make the car sit about 2" lower. Stiffens things up quite a bit and makes it handle much better for only a few bucks.
PostPosted: Mon Jun 11, 2007 10:20 pm
Will all 4 struts/springs bolt right up?
Is there anything I can do swaybar wise?
PostPosted: Mon Jun 11, 2007 10:46 pm
You can order the oem turbo colt sway bar from vintage parts thru a mitsu dealer. They have 1 or 2 left and theyre something like $75 bux.
PostPosted: Mon Jun 11, 2007 11:35 pm
You will have to press the stock metal lower bushings out of the rear Colt struts and use them on the DSM struts. For the fronts you'll have to cut about 1-2 coils off and then use the Colt's upper strut mount. There is a writeup in the Archives labeled "Budget suspension upgrade" or something like that.
PostPosted: Mon Jun 11, 2007 11:51 pm
You'll be good to go with 4 AWD shocks/springs. Should be well under $100.
PostPosted: Thu Jun 14, 2007 1:11 pm
24hoursofmirage, check out you pull r parts , that is where i got the old set of springs/struts for that. http://www.upullrparts.com/index.cfm/go/yard.home , and its $14 for each strut assembly and $9 for each shock assembly.
PostPosted: Thu Jun 14, 2007 2:29 pm
Thanks for the tip! I forgot about Upull! They have a 90 Mirage 4d in stock, do you know if the front glass is the same as the hatch?
P.S. We managed to strip off almost 100lbs from the car so far, did you ever weigh it in the state that you sold it to us in?
PostPosted: Thu Jun 14, 2007 10:45 pm
the front glass should be the same, as far as weighing it.. i never did... what did it weigh before you started striping it?
MyRaceCarPics
MyWebSite
  • 2.0 dohc n/a swap
PostPosted: Thu Jun 14, 2007 11:09 pm
Not sure....Stock weight is about 2200lbs though....I figure you probably eliminated a few hundred pounds of it.
