that's some good stuff going on out there in Jamaica man.
I'm here in Trinidad and we are yet to get as organized as you'll when it comes to legal racing activities.
I'm doing over a rebuild of my 4g61T presently (the right way - blueprinting) but it will not be for all out racing.
The 4g63 head you intend to put on has a 47cc compression as opposed to the 4g61/4g67 which have 43cc. Ultimately, i've been told your compression will drop to below 8 (7.XX) which is not really the best thing. you'll have to crank boost up to compensate somewhat and i've been told off boost performance will suffer. you should look for the 4g67 head in particular. its a nice balance of port size (for flow) but retains the compression balance. Hyundai Elantra (92-95 models) carried the same head as well.
bfrontin, thanks you!! Finally some empirical data. I am running a TRE Modified Gearbox with an Evo 1 Final Drive and Quaife Front LSD, shifts fine up to 9000 rpm. I have to declare the engine size at scrutineering, otherwise everyone will cry foul when they see how low the car weighs. Regarding the compression ratio loss, I'm thinking of having sum custom high compression forged (9.5:1 ish) pistons made. When I called CP Pistons they said they were working on one from somone from Trinidad. Is that you??? Do great minds think alike???
that would be very interesting, cuz as far as i was aware, im probably the only 'driving' 61T out here. another buddy of mine is all setup, but he wants someone to check over his wiring before he fires up.
other than that, most cats here stick to the 63T, so maybe the CP people got mixed up. but then, 63T pistons are common place, and can be ordered right off the shelf, if these guys are building something custom, then maybe it is 61T pistons! who knows! but ill be VERY interested to kno who else got BRIGHT!
and there's loads of good stuff here on this site. these guys are really the authority when it comes to these motor types. ive gotten just about every issue ive had with my motor sorted out thru the info and great folks up on here.
but i have been a huge fan of the 61T over the 63T cuz its special to cut ass with 1600cc! im only at a modest 200 whp/180 trq with a f*cked motor and stock internals. probably u kno the name Ryan Garcia - he powered a old model (box) lancer (SKF sponsered) with a 4g63 to 7 secs on the quarter. he's doing the rebuild for me right now and we've targeted 260-280whp as my ceiling due to a crappy KM206 gearbox (non-turbo).
let me kno how this develops. very interested!
