It is currently Sun Nov 02, 2025 9:27 pm
Post new topic  Reply to topic  [ 29 posts ]  Go to page 1 2 Next
 Post subject: Fuel Filler problems
PostPosted: Thu May 03, 2007 9:40 pm
So I had issues with the gas pump overflowing after a gallon or so. I INCREASED the slope into the gas tank and it STILL overflows after a gallon or so. WTF.
Here are some pictures
http://www.lilevo.com/lilevo2/gasfiller/
What is the problem here? Do I need an even greater angle into the tank? The rubber hose and metal couplers are all stock fuel filler parts.
PostPosted: Thu May 03, 2007 10:51 pm
Fluid might not be evacuating or is backing up in the overflow chamber - the small tube. I don't know what a good solution may be, but compare the tube position/orination to stock models, and see what may be different with regards to tubing locations and there orientation to one another. It must be simple issue. I've heard that the new generation of Mustang owners have had brutal problems trying to fill their 2004+ cars at the gas pumps. Some pumps are finicky and pump faster than others, but that depends upon calibration, and the other factor is how much the filler system can evacuate compared to the quantity being pumped in.
Decisions, decisions .....
PostPosted: Thu May 03, 2007 10:54 pm
The tank is basically on "E" when I tried filling up the past few times so the gas must be pooling up somewhere in the filler tube. It has to be that last bend into the tank.
The smaller tube is never wet with gas since it's at the very top of the tank. (I pulled it off today) That's basically there for the air the gas pushes out of the tank as the gas goes in. Think of a 5 gallon gas canister with the air hole at the back of the canister.
Like the pump doesn't just click and shut off when fluid reaches the top. It overflows, spills all over, and then clicks off. Happens at every gas station I go to.
PostPosted: Thu May 03, 2007 11:07 pm
:-? Well, design may be the biggest factor then; it just might be able to evacuate the amount of fluid coming in, but I'm surprised the pump does not click off. It's pressure hitting the pump feed orifice that gets it to turn off right? Gas station physics 101 eh. :lol: Anyone know the science behind the gas station pump kick off feature?
PostPosted: Thu May 03, 2007 11:26 pm
BAM!
http://www.pa.msu.edu/~sciencet/ask_st/122591.html
89' Mitsubishi Mirage Turbo.
PostPosted: Fri May 04, 2007 1:32 am
The only thing I noticed was the smaller line was labelled "not for fuel use". If the gas were to get up to the top of the filler neck it should shut the pump down. The last one I looked at had a tiny tube inside of the nozzle, this is the sensing line for the shutoff.
I would do as already mentioned, and compare to some stock awd talons. See how many bends are in that setup, maybe there should be a sharper bend closer to the fuel cap.
P.S. - I would still rather live with a slow filling setup compared to driving around with the windows down after filling up.
- Works in da bush
PostPosted: Fri May 04, 2007 10:33 am
I'm going to assume it's because its totally on E.I would have that problem if it was hot and on E.But it wasn't AWD specific.It happened on my Armada.
PostPosted: Fri May 04, 2007 7:31 pm
Are there only two hoses that connect to the tank - by this I mean fuel to and from the motor - there isn't a vent to the charcoal canister being blocked off?
PostPosted: Fri May 04, 2007 9:21 pm
-Hose out of pump
-Return from fuel rail
-Small hose to filler
-Large gas filler
-Line to canister (on tank) is taped/blocked off.
PostPosted: Fri May 04, 2007 9:50 pm
Is the tank vented? Try closing it off a little so there's more pressure to go to the kick off switch in the pump.
PostPosted: Mon May 21, 2007 10:57 pm
SO will it fill slowly without overflowing?
Also I like how the lines you installed say" not for fuel" on them
Adam
93'FD Touring non-seq
05'WRX
PostPosted: Tue May 22, 2007 10:03 am
Blah, I'm pretty sure they say "not for fuel injection use" which would imply high pressure use.
I installed a 2" mandrel bend at the tank, re-adjusted the remaining filler hose, and used 2" hose half the way up. The filler *still* overflows. I can fill roughly 1 gallon before the pump clicks off. I have to then wait approximately 5-10 seconds and fill another 1 gallon. Repeat x 10.
PostPosted: Tue May 22, 2007 12:11 pm
did you stuff a rag in the neck while you were installing the tank and forgot about it? thats the only thing i can think of.
PostPosted: Tue May 22, 2007 2:13 pm
Nope. Unless it has something to do with the tank outlet to the charcoal canister or not being able to create positive air pressure out of the vapor line. I'm out of ideas.
Anyone else with the AWD swap using a stock gas tank? Any problems filling it up?
PostPosted: Tue May 22, 2007 3:54 pm
There's a vent line with a one way check valve [blue little thingy] Do you have it installed so it allows fumes to vent TOWARDS the front of the car?
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
