It is currently Sat Oct 25, 2025 3:48 pm
PostPosted: Fri Jan 12, 2007 8:50 pm
Chopped out the flore pan.
and everything else. :P
The Rear "boomerang" with some support
Frame rail befor cutting it up :(
And after
and another of the frame rail with the front plate tacked on it.
I got alot done today. I got both frame rails cut out. and the plate tacked in place. I also got the rear sub assembly in and also tacked in place. I got everything square. and Everything is titties.. Almost.. :( We measured everything again. and its to the passenger side a little less then 1/8in. But other then that everything is perfect. I guess i'm grinding the welds and fixing that part monday. So far all is going smooooth
PostPosted: Sat Jan 13, 2007 3:00 pm
And here's some more pictues.
view from back of hatch
From the bottom
my super sweet 4lug hubs
The front subframe mounts.
4bolt rear diff cups.
Now i dont have to get my tags changed.
PostPosted: Sat Jan 13, 2007 3:02 pm
Let me know what you guys think :drinkers:
PostPosted: Sat Jan 13, 2007 3:10 pm
Looking good so far keep the updates coming! :)
PostPosted: Sat Jan 13, 2007 3:23 pm
I just have a few Questions. I see you have a four lug rear end and 4 bolt. The Eclipse has 5 lug are you running a Galant rear end? I was woundering I'm going to be doing the swap soon. Any help would be great.
PostPosted: Sat Jan 13, 2007 3:30 pm
Everything i'm using is out of a 92 AWD laser... The 4 bolt rear diff/trans/tcase. sub frame.
I did buy galant vr4 rear 4lug hubs so i could keep it 4 lug. And they werent tooo easy to find.
PostPosted: Sat Mar 10, 2007 7:37 pm
"SPNN AL4" Good Sh!t
PostPosted: Sun Apr 01, 2007 4:51 am
this long without an update will make you die in your sleep...
:lol:
PostPosted: Sun Apr 01, 2007 11:07 am
:lol:
hahah.. theres some pics in this thread http://forum.4g61t.org/viewtopic.php?t=20641
http://forum.4g61t.org/viewtopic.php?t=20205
PostPosted: Sun Apr 01, 2007 3:36 pm
Very impressive! I am a big researcher and have collected virtually all the info. on this subject. I am appreciative to all. Anyway, I still haven't started on the actual conversion. I am still rebuilding the Colt/Mirage (it's half anf half). I found out that the control arm balljoint is an integral part of the control arm. However, the small dust/grease balljoint cover is replaceable, but there is a special tool for a replacement. (It looks like a 2.5" sleve to go over the cover and drive the edge, which has a steel belted core, into the control arm.
PostPosted: Sun Apr 01, 2007 3:41 pm
Bill, the balljoints are replaceable, they have to be pressed in to the control arm:
http://www.autozone.com/servlet/UiBroke ... nt+-+Lower
You can also rent the balljoint press from them as well.
PostPosted: Sun Apr 01, 2007 4:00 pm
4wd truck balljoint C-clamp kit got me through this and brake piston repairs, and for the measly price of $29.95 plus tax from you equivalent to Harbour Freight. It is the best money you will spend on a cheap tool, and will allow you to press more than ball joints. Great multi-purpose tool for the money!
So, any updates on this AWD swap Red Sleeper??
PostPosted: Sun Apr 01, 2007 4:15 pm
If you will use it more than twice, it is worth it since you have to pay $100 deposit+tax on the autozone tool and you don't get your tax back at return.
PostPosted: Sun Apr 01, 2007 8:38 pm
AS for the update. the car is 99% done. We started it wednesday of last week. and finished up everything else. And my driveshaft will be done tomorrow. I'll havve more pictures up ASAP
