It is currently Thu Oct 30, 2025 12:39 pm
PostPosted: Sun Jan 07, 2007 1:53 am
1. http://www.dsmtuners.com/forums/showthread.php?t=237982
2. http://www.dsmtuners.com/forums/showthread.php?t=105573
so guys...which one seems more correct?
there seems to be a conflicting school of thought!
ive got the in-car MBC and im wondering as well, if running these vacuum lines into the cabin will cause boost spikes etc? what about the setup would prevent this.
turbonetics in-cabin MBC.
thanks
96 Lancer Stationwagon - 4G61T swap (rebuilt) (4g67 head, 4g63 intake mani), 390cc's, ported exhaust mani/with 2.5" custom d/pipe, TD04-13g (ported), Greddy Emanage (Gold Edition), VR4 18x12x3 IC with custom piping/hose, SR-20 (Silvia) Recirc BOV, Walbro 255lph pump, custom 2.25" press bent de-cat exhaust, ACT 2100 (4g67 g/box), front EVO II brake/booster upgrade
PostPosted: Sun Jan 07, 2007 2:08 am
I prefer the method in your first link. I've tried both ways on my car, and using the ones right off the compressor housing just gives me a much more solid number. I'd get a small spike when I ran it off the BOV line. Either will work, but I always hook it up to the comp housing. P
lus I don't like to use Tee's where I don't need to, and the install usually looks cleaner, and less vacuum line strung through the engine bay.
PostPosted: Sun Jan 07, 2007 11:35 am
I use the first one myself too. Worked good for me, never had a problem related to where i got the source from.
- Works in da bush
PostPosted: Sun Jan 07, 2007 1:34 pm
My pressure source is off the manifold because the gate will stay closed longer between shifts which keeps you in boost just a touch longer. I tee the BOV into that line also.
1999 Ford Contour SVT
PostPosted: Sun Jan 07, 2007 1:37 pm
I have always used the second and had no problems. I can not even use the first one on my colt because I dont have the nipple on the elbow since I made my intercooler pipes.
PostPosted: Sun Jan 07, 2007 1:47 pm
Either one will work Brian. You may as well utilize the nipple on the compressor outlet :wink: You can run the mbc under hood as well, just keep it away from alot of heat.
