The problem with the 4g15 carby isn't so much the carbueration but the carbuerator. It is cheaper and easier to ditch the stock Mikuni Solex 30-32, and replace it with a better carb than it is to dismiss carbs altogether. Consider this, to replace a carb system with a TBI (which is by no means a instantly superior set up) you need to replace your mechanical fuel pump with an electrical one, than add a fuel regulator, replace the primitive ecu (and this is only if you have the Feed back carb, other wise you have to install one, and all the sensors), put in the new ecu, run whatever other sensors have to be run, run a different throttle body cable, and there is more to it. Holley makes some carbs that are much less restrictive, the 4412s is a stock replacement, but there is also the 5200, which is really an imitation weber, and of course, there is the down draft weber. Installing any of these would be much cheaper and easier, requiring re running the throttle cable. There would be power gains there that are definate. if you need more up grade your mechanical puel pump, or back it up with an electric 3-8 psi pump.
Also definitely go with a bigger exhaust and get rid of at least one of the catalytics, or replace them both with one two inch. exhaust back pressure is probably most of this engines problem any way.
But I would not be so quick to ditch to carb. besides on race day, having some thing "wierd" could definately work to your advantage. Good luck!
