It is currently Sun Oct 19, 2025 3:58 pm
Hi, im from New Zealand and drive a C63a 5 door lancer hatch, im not sure how popular these are in the US, so i thought id post a pic and some info and see what you think:
1988 Lancer gsr
4G61T
Fwd
Stock TD04 running 13 psi
VR4 IC
16" ROH reflix rims
2.5" exhaust
No Cat
450cc injectors
2G MAF from 1.8 turbo lancer (similar but samller than Evo MAF)
K&N filter
IC water spray
Momo seats
Factory electronic adjustable suspension.
Stiffer Springs
With stock injectors, stock MAF, and 12psi boost i've done a 7.00 0-100 kph, and a 14.98 1/4 mile at 160.2 kph (with little traction) And on they dyno 130 Hp at wheels. How does that compare to other 4G61T's with similar mods?
What would people recommend as the next mods? Im thinking VR4 cams - are they differnt to the 4G61t cams? i thought the head was the same? And bigger fuel pump, then probably TD05 14B.
The picture is a little different to what the car looks like now. It has no white stripes anymore, a VR4 front mount IC, and no rear wing.
Thanks for any feedback
<IMG SRC="./uploads/this pic.jpg">
