It is currently Mon Oct 20, 2025 12:42 pm
PostPosted: Fri Nov 14, 2008 12:36 am
well here is my soon to be 4g63 colt .. just have some harness intalation left .. here are some pics of it throught the transformaition
PostPosted: Fri Nov 14, 2008 1:47 am
Awesome! What transmission are you using? Clutch/flywheel setup?
PostPosted: Fri Nov 14, 2008 5:04 am
Looks like a 2.0 D50/MM tranny.
PostPosted: Fri Nov 14, 2008 8:13 am
Truly a worthy project! I'm sure this will bring a smile to your face when it's finished, and just may keep it there (the smile) for years to come too. Quite an accomplishment to have come this far into the project. :twisted:
PostPosted: Fri Nov 14, 2008 10:43 pm
:o :o :o ::breathless::
PostPosted: Sat Nov 15, 2008 12:57 am
nope the tranny is the stock km132 4 speed manual .. yeah she is quite the porject as for the clutch its the stock 4g63 (eclipse) the volvo turbo in the pics is a 18g off a 6 cyl
and thanx most people arnt that interested
PostPosted: Sat Nov 15, 2008 1:27 am
Funny seeing you here! Now you are in my neck of the woods. pttcolt pokes around here also.
RWD > FWD :axe:
PostPosted: Sat Nov 15, 2008 10:14 am
RWD > FWD :axe:
yeah i saw dj and 89coltgt aswell
PostPosted: Mon Nov 17, 2008 1:57 pm
I've seen one of these prowling/drifting around my parts. With fatty tires on the back, :supz: .
Was the stock engine a g32b, g54b?
How did/will you fix that rusty part under the drivers door, kitty hair?
PostPosted: Mon Nov 17, 2008 2:00 pm
4G32 I believe. 1.6 liter SOHC monstrosity.
PostPosted: Mon Nov 17, 2008 11:26 pm
i had the 4g32 then i rebuilt it then i ripped it out ... and that is not kitty hair its bondo hair ( fiberglass) and i just put it there for a more rigid contruction i will put metal over it .. :D
PostPosted: Tue Nov 18, 2008 3:33 am
how did you get the throtolbody (sp?) on the front side of the motor?
PostPosted: Tue Nov 18, 2008 11:49 am
He had the stock intake manifold cut and welded.
PostPosted: Tue Nov 18, 2008 3:57 pm
That thing's fruit and banana dope for real. I need to see a video of it when you get it running.
PostPosted: Tue Nov 18, 2008 8:38 pm
a guy named bill hitcher did it and he did a fantastic job ..... i will be sure to post a video of her running and ill be sure to tare it up a little :supz:
