Wow it has been awhile since i have updated this, where to start...
Personal life has changed a bit, i am now self-employed and my partner is 5 months pregnant with our first daughter, car had taken a little back seat for the last few months while i worked on a major implementation project over xmas/new year’s.
I have been relaxing for the last week and have made some progress.
Story since last update,
Got the car going, would not shift into any gears when stationary, just grinded the gears. could stop the engine select the gear then start the car and get moving, once moving you could shift, but not very nicely. bleed and re-bleed the clutch, checked clutch pedal adjustment, nothing made it better. When it was hot it would also run on three cylinders, traced that to a dodgy coil pack, replaced that and it was slightly better, but i couldn’t really drive it anyway so i left it for a bit.
Decided the gearbox had to come out to see what was up with the clutch, pulled the box out on xmas day
When i pulled the box i noticed little bits of friction plate cushion springs in the bell housing, turned out about three of the springs had partially collapsed and there was even excessive wear on the cushion spring retainer plate after only 30kms maximum worth of driving.
i decided to change friction plates and purchased a ClutchNet 6 Puck Sprung Centre off eBay, ClutchNet friction plates seem to be very good, their sprung centres are the only ones available with the springs completely close off to its impossible for them to wear loose and take you whole clutch assembly out.
I also changed from the fidanza alloy flywheel to an ACT Streetlite chromoly flywheel, the main reason for this was previously when the car was going with the fidanza alloy flywheel after a few hours of beat downs the clutch assembly would over heat and slip, i am not sure if it was the flywheel, friction plate or pressure plate responsible for the slipping when hot, but i did read that fidanza alloy flywheels can warp when hot due to the different expansion rates of the materials used (aluminium and steel).
I measured the ClutchNet friction plate thickness compared to the fidanza one which was giving me issues and the ClutchNet was .1mm thicker. because of the previous clutch dragging issue i decided it would be best to shim the clutch fork pivot ball.
had a little issue with 5th gear too, because the nut on the input shaft had backed out previously and broken the gearbox end casing, i switched to a spare case i had in the shed. The end case i had was slightly different though, it didn’t include a wave spring for the reverse gear synchronizer. so i thought, if it’s not there then it doesn’t need it. But because of that these things kept falling out when reverse was selected.
I found out later that there was a cover plate that i didn’t put in and numerous other tiny differences with the synchronizer assembly that are not totally apparent. seems there are two distinct KM221's and early and late model with different 5th gear and reverse assemblies and i got them mixed up.
So got the new clutch in put the car back together last Saturday. did some re-shaping of the scatter shield because it was putting a bit of stress on the shifter cable making selecting gears abit harder than normal. Filled all the fluids up and started her up. clutch works thank fruit and banana!
Have done about 200kms so far, no fluid leaks either! i still have a rev limit of 4,000rpm because i haven’t tuned for the changes in fuel delivery that will be required because of the new cooler and manifold.
initial thoughts on the changes so far seem that the turbo comes on boost a lot earlier, around 3,800rpm in 3rd where it used to be 4,200rpm so at least something has been a positive.
So anyway, back to today.
I was having difficulty ensuring i had all the air bled out of the water to air intercooler system. so i went out and had a bleeder point welded onto the top inlet of the barrel, this is the highest point of the system in the engine bay and I’ve already managed to bled it correctly in a few minutes.
Next on the list was to upgrade the ECU. To recap, i am running a LinkPlus G3, it was top of the line a year or to ago. Since then they released a G4 ECU, new pricing and feature structure, but the funny thing is the only hardware difference is the harness plug connector style. Link offer a firmware upgrade for older LinkPlus's to G4 spec which give you all the new advantages (better logging, autotune, update tuning software etc). Only issue is the old tune needs to fully re-done as there are so many changes to the ECU that a straight upgrade isn’t possible.
So i have done the ECU upgrade, i just need to start making the new MAP up, i will be road tuning it this time, and it will be getting tuned this week.
