It is currently Mon Oct 20, 2025 1:51 am
 Post subject: 5OBAIT from NZ
PostPosted: Mon Jan 16, 2006 2:06 am
Hey guys. Another Cyborg from the 4G61NZ site along with GSRWRC & Snowdevil.
Its a 4wd Sedan which is pretty rear over here.
Its still got the 1600 but Mods include:
VR4 Turbo, injectors, ecu, afm, throttal body, fuel pump.
Turbosmart BOV & boost tap.
Tial 38mm External wastegate.
Fuel regulator.
Custom front mount.
K&N pod filter.
2 1/2" exhaust system with 4" dumped tip.
Lowered on 17s
Probably forgot something but thas that guts of it.
Interior mods include:
Monster tacho with shift light.
Boost gauge.
Recaro evo 4 seats.
Sony Head Unit with Sony 6" speakers in the front doors. Sony 6x9s in the back tray. 2x12" Cerwin Vega subs in the boot - only just fits!!
It recently ran a 13.906 at 159kms down the quarter. The reaction time was a bit slow so with some quicker launchs should get better times.
Since these pics the rear wing has been removed. Apart from that the body work is still all factory.
sorry always have trouble posting pictures up. If you copy the link & paste it to the address you will be able to view the pictures :oops:
Its only illegal if you get caught!!
PostPosted: Tue Jan 17, 2006 1:39 am
img tags wont work unless the url ends in a .jpg or whatever file extension. You can use the links I have in Photobucket that I posted on ImportX
EDIT: Weird, not working for me now either :-?
Edited by netninja2001, you're welcome :wink:
www.4G93T.net | www.4G61NZ.co.nz | www.SquidInc.co.nz | <RR>
PostPosted: Tue Jan 17, 2006 1:50 am
btw, just cause that ended in .jpg doesn't mean it was a picture... it still points to an html file on photobucket. you need to right click the actual picture, click properties, and then use that address...
PostPosted: Tue Jan 17, 2006 5:29 am
Welcome :) :lol: 8)
PostPosted: Wed Jan 18, 2006 3:25 am
where would i be if it wasnt for u fixing up all my errors on other sites GSR :oops:
cheers for posting those up guys.
