My Colt http://www.4g61t.org/forum/viewtopic.php?f=9&t=11589 |
Author: | gonzo [ Wed Nov 10, 2004 4:58 pm ] |
Post subject: | My Colt |
1989 Dodge Colt Swapped 4g61t for the 1g Eclipse 4g63 Balance Shafts removed 2g Ported exhaust manifold Evo 3 16g 550cc Injectors 255 Fuel Pump/Rewire 2 1/2" SS Down Pipe Hi-Flow removebale cat Bullet Muffler Custom 2 1/2" Press Bent (yea it sucks) Exhaust Manual Boost Controller Greddy Turbo Timer Analog SAFC Relocated Battery 20"x6"x3.5" FMIC with 2.5" piping Homemade IC Sprayer Eibach FWD 1g DSM Sportlines KYB AGX 1g AWD struts front and rears Hyundai Valve cover (just to throw you off) plus it gives it bling 2nd DSM MAF K&N Filter Home made shorter throw shifter VDO Gauges (oil press and Boost) Air Fuel Gauge EPROM ECU w/Key Diver Chip Good enough for a 12.7@111mph with pump gas and 18 psi 110 octane and 22psi was rated for 315 whp and 334 lb/ft torque |
