So I finally uploaded some pics of the 4G61T Excel into my Album.
http://www.4g61t.com/forum/album_pic.php?pic_id=286
http://www.4g61t.com/forum/album_pic.php?pic_id=287
http://www.4g61t.com/forum/album_pic.php?pic_id=288
Specs are as follows:
Hyundai 4G61(G4CL) block w/ ARP head studs
Hyundai head stamped "1.8L" flow-bench ported
Mitsubishi "ECI Multi" 4G63 inlet manifold port-matched
RPW bored 64mm throttle body
1G/GVR4 exhaust manifold w/ HPC Hipercoat Xtreme coating
TD05/14B turbo w/ HPC Hipercoat Xtreme coating on turbine & O2 housing
450cc "Blue" injectors
Malpassi FPR
All 3 engine mounts polyurethane
3/8" fuel line into Ford inline filter custom NPT fittings
Knife-edged crank w/ ARP mains
Shot-peened and crack tested 1G conrods w/ ARP bolts
Full "neutral balanced" bottom end
8.8:1 CR hyper-eutectic flat-top pistons w/ ceramic coated crowns and moly coated sideskirts
Tighe Stage 2/3 turbo camshafts/3G HLAs/valve-springs to suit
Remote oil filter w/ inline oil cooler
2.25" alloy IC pipes
Big-as-will-fit FMIC
Davies-Craig electric water pump w/ EWP controller
Haltech E6K ECU (MAFless)
KM206 trans (for now)
4-puck clutch w/ super HD pressure plate
Hydraulic clutch MC from Excel X2
2.5" mandrel bent SS exhaust w/ 3" dump, SS Lukey Ultraflo muffler no-cat
190lph Fuel pump
RPW Excel X2 "short-shifter" with conversion to cable gear change
330mm drilled/slotted DBA rotor front brakes with 2-spot PBR callipers
Full KMAC suspension inc o/size front struts, variable rate 2" lowered springs, front & rear sway bars
All suspension bushes polyurethane
17" Speedy rims w/ Dunlop 205x40x17 FM901 rubber
Turbosmart Type 2 BOV
I think there's other stuff that I cant remember right now
Future mods are:
KM210 trans w/ Quaife ATB diff
Strut brace
More boost (currently at a piddly 5-7psi
needs to go back to dyno)
Quicker steering rack
Autospeed DIY EBC (when it comes out!)
Adjustable coil-overs for the front
maybe one day I'll consider an AWD conversion but I think I might do that to the Lantra instead.
