Completed the intercooler setup. Mounted/secured front bumper (it's only on with two bolts, but it's snug as a bug in a rug!). Completed TPS wire harness cut/paste. Hooked up all vacuum lines. Connected A/C harness and knock sensor harness. Hooked up a few other things. Connected starter harness. Installed intake.
I still need to figure out wtf I'm gonna do with the coil pack. The GVR4 one is 4-wire, the Mirage one is 3-wire. None of the wire colors match up. So at this point, I'm probably going to remove the GVR4 coil pack and use the Mirage one....hopefully I'll be able to mount it securely somewhere.
I STILL need to tighten the lower motor mount. But I did jack the car up higher (that's how I did the starter, knock sensor, and A/C hookups). I also need to connect the A/C lines to the firewall, tighten the strut bolts, bolt up the wheels, change the oil, change the tranny fluid, and change the spark plugs. Oh yeah, and that fruit and banana full tank of ancient gas.
I really only have a couple hours of work left to do. I might even work on the car a little more after dinner.
Oh yeah, and my bro already scored me a pair of bumper lights for the Infiniti bumper. They're waiting for me down in FL. So I'll only be ghetto style for a little bit.
