update time,
for the last few months i have been off work because of a mystery illness that i have had for the last two years but which had progressed to the stage where i couldnt get out of bed or work. managed to see a new doctor who has given me some pills just for the pain and now i can actually get up and move about during the day which is friggin awesome.
anyhow, i've been out of bed for the last two weeks and finally started working on the borg again!
i've always wanted two 12"s running atleast 1000watt combined, but due to space limitations i had to settle with only one 12"
so i ended up getting a 12" Pioneer Competition Pro 3500watt sub and a Apline PDX.1000watt amp, i chose the Apline amp because it has a fruit and banana load of power but is very compact in size. i am really starting to run out of room... everywhere...
the sub box is EXACTLY the correct size as per the subs specs, i tried to make the sub box the same general shape as the W2A res, to try and stop it looking out of place.
but because i had to deepen and length the sub box so i could get the correct cft i needed to change my primary circuit breaker to this.
all the gaps you see are allowances for the carpet which is 3mm thick. i like the hard wearing stuff
i am half way through re-wiring the boot for the amp and W2A water pump, with a bit of luck that should be done tomorrow. then its just final trimming of the custom wood and carpeting.
