Little update just cause I haven't done one in a while...
Took it to the drags a few times since my last post, but every time I take it the gearbox seems to get worse. It's practically impossible to hit 2nd after a hard launch now, and 3rd/4th aren't much better. All my runs lately have ended in 13.0-13.2 @107-109mph. Also my clutch (just a standard replacement with a slightly uprated pressure plate) now slips on launch. It's done bloody well though, handled 2 years of abuse and well over 50 hard launches at the track, and only started slipping after I tried a 2nd gear launch, my bad
. Anyway it still holds up during normal driving/boosting, i'll keep it till it totally craps out and then upgrade to an ACT or something.
Other than that, the car has been totally reliable, i've been daily driving it for over a year now (apart from June-July last year when I was upgrading the turbo), and it hasn't broken even once... which is a record for this car!
Anyway i've never really been happy with running this setup on the chipped VR-4 ECU, it seems to run alright but I just don't trust it especially with no piggy back fuel control or anything. The car has been having some weird random starting issues (during warm weather or after it's been sitting for a while, it fires on the first crank then dies, and gotta crank it for another 5-7sec before it finally coughs into life). Also during warm weather it seems to buck when cruising/decelerating. I've managed to trace this down to ECU caps starting to leak, so I decided i'd use this opportunity to upgrade.
So I bought a Link G4 VR-4 Plug-In ECU. Link Engine Management is a New Zealand company, I don't think they've established a name for themselves overseas (apart from Australia), so you guys probably haven't heard of them? This things pretty awesome though, slots right into the stock ECU case for a factory look, and plugs in to the standard wiring harness.
http://www.linkecu.com/products/engine- ... ug-in-ecus
Generic pics of the Evo plug-in model, VR-4 is pretty much the same but with VR-4 plugs obviously
Also picked up a pair of Kelford 264's. Next on the shopping list is valve springs, 880cc injectors, some sorta BOV to replace my factory plastic Evo 1-3 unit, new clutch, and then finally chuck her on the dyno for a much needed tune!
Might be a little while before I can afford those bits, the ECU and cams have cleared out my account lol. But for the first time in a while, i'm actually excited about this car
