i may be missing a few things, but:
JDM front bumper
stock 4g63 longblock
re-cast 1g replica cast iron manifold
thicker 7cm turbo gasket
PTE 60-1 to4s housing
Bullseye adapter housing w/ 38mm flapper
Victory Performance tubular o2 housing w/ 38mm dump
AGP o2 mounted actuator
socketed/keydiver chipped ecu
afc II
3g/evo mas w/ adapter harness
780cc injectors
frontmounted i/c
Centerforce 2500lb pressure plate
Mitsubishi OEM AWD organic full-faced clutch disc
greddy type s recirculated
3" dejon tool intake pipe
supra fuel pump
Greddy peak-hold EGT
Autometer electronic oil pressure
HKS turbo timer
aeromotive fpr
urethane motor mount inserts
modified Galant 2.4L transmission
Innovative wideband
Galant vr4 hubs
Diamante twin-piston calipers
agx front shocks
gr2 rear
lowering springs ?brand?
switch to 94 CAS
modified injector clips
15" galant "wagon wheel" with M.T. slicks
soon to be installed:
4-layer metal headgasket
arp studs
built head
im lazy, so here's a link to my local site:
http://www.dallasimports.net/forums/ind ... opic=37398
