http://www.4g61t.org/forum/
4G63AWD AUTO 1992 colt -updated new parts
http://www.4g61t.org/forum/viewtopic.php?f=66&t=40183
Page 1 of 1
Author:  Autocrossn [ Fri May 29, 2015 10:39 pm ]
Post subject:  4G63AWD AUTO 1992 colt -updated new parts
Life events came up and i need something more practical than a racecar... so parting her out to buy a vr4
here is the build thread
http://www.4g61t.org/forum/viewtopic.php?f=64&t=39165
and the photo bucket album
http://s1278.photobucket.com/user/fjajo ... lt%20Build
2g dsmlink with eprom ecu and cable $550
AEM 5 bar map sensor $75
Evo 8 recaro seats 400 obo
Driver side has a 3 inch rip on the left side on the side of the seat
Passenger side is in pretty good shape
1g 7 bolt long block (planned on going with hx35 hence the mods..) $1100
70k on stock bottom end
-12 an drain welded on pan
brand new front case
Balance shaft delete
Straight cut oil pump gears
all new gaskets
Cometic mls head gasket
arp head studs
2g head
comp stage 3 cams (meant for big bolt on turbos)
dual valve springs and titanium retainers
Brand new valve stems seals
Gates water pump
Brand new oem timing belt and tensioner
have pictures of it being 140 compression on all cylinders (ENGINE WAS COLD as i never got car finished)
Shaved valve cover with -10 lines and catch can $200
1g awd auto 0 miles since new parts $800
IPT Shift kit
Ipt end clutch
Kiggly front clutch
Oem filter
new pump seal
stock converter
1g auto transfer case $100
Fuel
Plastic fuel cell with -6an dual feeds and -6an return $100
Bosch 044 pump $100
Fuel lab filter and rustle pre pump filters $75 0 miles on them
-6an tank to rail feed and return $100
fuel rail powder coated black with -6 feed and return $45
fuel rail -6an feed and return $35
fuel rail -6an feed $25
50 ft of -6an $3 a foot
Black top cas $60 shipped
Green to cas $35 shipped
1g head no cams $100
Turbo
SBR manifold with 38mm wastegate $125
Tial 38mm wastegate $125
Tdo5 20g 3" compressor inlet no cracks 0 miles on fresh rebuild $450
2g manifold with egt port $40
1g auto manifod for 13g $20
2x turbo xs BOV $30
2g side mount hard pipe for greddy bov $20
14" steelies (brand new 0 miles) with hankook slicks $300 fit 1g small brakes or 2 gst brakes (big brakes if you
grind the caliper a tad or run a spacer) $300
1g small front brakes and drilled/slotted rotors $75
1g rear brakes and drilled slotted rotors + new pads $50
2g big brakes $50
Also have braided brake lines same thing as STM abs delete kit!
$175
Also have an assortment of 1g axles
Author:  Autocrossn [ Sun May 31, 2015 11:21 am ]
Post subject:  Re: 4G63AWD AUTO 1992 colt
Will sell the car the way it sits for $4500
Author:  Autocrossn [ Wed Jun 03, 2015 5:53 pm ]
Well after talking to my grandparents.. its getting stripped and taken to the yard..
Unless someone wants to come save it.. its going to kill me todoo somthing like that to such a clean car
Author:  89Mirageman [ Wed Jun 03, 2015 7:42 pm ]
Sad to see a nice shell get scrapped but like most projects, they're worth more in parts.
Author:  Flying Eagle [ Wed Jun 03, 2015 9:24 pm ]
Any chance you can save the parts I was offering to purchase?
PM'ed you.
Author:  Autocrossn [ Wed Jun 03, 2015 9:29 pm ]
I didnt get a pm from you Flying Eagle
Author:  Flying Eagle [ Wed Jun 03, 2015 9:44 pm ]
Should have gone through at 10:33. :)
Author:  Autocrossn [ Fri Jun 05, 2015 1:28 am ]
bump updated the parts list.. selling all the dsm parts
Author:  tractionlesscoltgt [ Thu Jun 18, 2015 2:47 pm ]
Post subject:  Re: 4G63AWD AUTO 1992 colt -updated new parts
How much for suspension?
Author:  Autocrossn [ Thu Jun 18, 2015 7:43 pm ]
suspension is sold.. Car is getting crushed so all body panels are for sale.
Author:  Flying Eagle [ Sat Jun 20, 2015 9:28 am ]
You have PM.
Author:  win0857 [ Sat Jun 20, 2015 7:27 pm ]
I want the right side plastic inner fender well. It has like 3 bolts on the passenger side and a few bolts that hold it up to the radiator support.
Author:  Flying Eagle [ Sat Jun 20, 2015 11:43 pm ]
No word back on PM or Facebook yet.
Author:  Turbocoupe [ Fri Jun 26, 2015 4:34 am ]
Is the 2g dsmlink with eprom ecu and cable $550 still for sale?
Thanks!
Adrian
https://www.phpbb.com/
