It is currently Mon Oct 20, 2025 6:49 am
PostPosted: Mon Mar 23, 2015 10:07 pm
****$4000.00 FIRM CASH****
Look, 4k is my remaining balance with the shop who built it, so that's my bottom dollar. The long block a lone, not including turbo or mani or anything has more than 4k in it.
Selling my 1991 Dodge Colt. Motor is a shop built 4G63t with a Hyundai valve cover on it ;).
Brand NEW DSM FP Black turbo and BRAND NEW Forced Performance exhaust manifold-both ported.
Bought this car as a project and selling it that way. The car literally only need FUEL lines and fitting to start. Motor is fully built and done over by Big 3 Racing here in Ohio.
Car will be EASILY *CAPABLE* (it was built for that purpose) of making 600hp and at only 2500lbs, that's easily a 10 second car trapping mid 130's.
Where else can you get 600hp for less than $5000? No where.
This isn't your garage built junk yard type of project, this is expensive high end stuff that was paid to be put in THE RIGHT WAY.
Here our some more parts in or on the car. WITH RECEIPTS FOR MOST ITEMS.
1990 6 bolt 4g63t
1990 fwd turbo trans shep rebuild kit and welded diff.
Hyundai valve cover
1990 ECU/Harness
V3 ECM link
Expo van knuckles with brand new wheel bearings and 1g 5 lug hubs
New GSX 2 piston calipers with new pads and rotors
EMPI axles (pretty thick axles)
Equal length axles
Brand new KYB struts all around
Walbro 190 pump in tank (will need larger to run E85)
2g throttle body
ARP head studs
Wiseco Piston
K1 Rods
Fp black ported and polished
Fp race manifold
Full aluminum exhaust Rick made
1600cc injectors black ops
Aem fuel rail
Ecm fuel density
Custom made large core intercooler and piping all welded in house by the pros at Big 3!
Competition Clutch Stage 5- Strip Series 430 Clutch Kit
Competetion Clutch Flywheel- Forged
Lightweight Steel Flywheel
Aem failsafe afr gauge
Boost gauge cheap one
Hks turbo timer
Turbo smart waste gate I believe
Colt gt cluster
Full turbo back exhaust ALL ALUMINUM very EXPENSIVE and light weight!
I am asking $4000.00 for the car as is, take EVERYTHING and enjoy one hell of a monster.
The money wrapped into this car is around $15,000.00, I'm asking 38% of what it's worth and I think that's DAMN FAIR.
You can drive it or if you have the time and patience you can part it out and bring in WELL over $10,000.00 in parts including selling the shell.
Contact me if you're interested at 216-SEVEN SEVEN SEVEN-9868
WHAT THE CAR NEEDS TO RUN
it needs fuel pump/lines/fitting. It has a 190 pump in the tank, but isn't enough to supply fuel to the 1600ccc injectors.
You also have to just double check small things, make sure all bolts/fitting/clamps are snug and what not, then it's ready to be fired up and broken it, SHOP CAN EVEN VERIFY THIS!
Last edited by mikehuntisitchy on Sat Apr 04, 2015 11:52 am, edited 1 time in total.
PostPosted: Sun Mar 29, 2015 8:40 pm
bump! someone buy this, go 10's, make me proud. Thanks!
PostPosted: Sat Apr 04, 2015 11:56 am
Ladies, gentlemen. I have edited this post and I am selling the car as a whole.
I was contacted by Big 3 Racing, in regards of getting the vehicle out of their shop to free up space, they are SLAMMED with work and cars now.
They will not store it outside till the balance is paid.
I have dropped the price for the WHOLE project to the balance price of $4,000.00 FIRM
I have the craigslist ad here in case which is filled with pictures and photo copy scanned receipts for my parts. Thank You.
http://cleveland.craigslist.org/cto/4900833494.html
