http://www.4g61t.org/forum/
Knock board $80
http://www.4g61t.org/forum/viewtopic.php?f=66&t=38158
Page 1 of 1
Author:  Miragetbo1997cc [ Wed Oct 02, 2013 11:43 pm ]
Post subject:  Knock board $80
Im testing some boards and I have one up for grabs if someone wants to take and test one. They use a atmega 8 and a TI TPIC8101. I made these boards because I could only do three at a time. They are 2x3 inches and fit in a Megasquirt case. I have been testing one for 6 months now. Can run off 5 volts ,Or populate the 5 volt regulator and run 12v to it. I use a RGB led to show me on the dash to show how much knock.Green is low=>blue green=> blue=>kinda orange=>red is knock .Seperate 0-5v digital out. I use a USB converter like the one from ebay to use a serial terminal to change the frequency,gain, and integration time. I have some of those togo with the boards I have . As of right know I have one board in my car and one board built .The other not built. Just waiting for another knock chip. This one is tested and loaded I have another set on the way. These are tunable/universal.
I you like this "thingy" I made then when the new ones show up I'll trade you.They are half the size and have a headphone out jumper and volume control.So you can verify the knock. Email insaneimport@verizon.net
I like it so much I had to get another opinion.
Author:  Miragetbo1997cc [ Sun Oct 06, 2013 11:09 am ]
Post subject:  Re: Knock board $80
http://youtu.be/LuT_vhahwHM I guess it would help if ya'll knew what its supposed to do.
https://www.phpbb.com/
